WFS on 4.4.1 works and not on 4.6.0
Simpson
asimpson at I-55.COM
Thu Nov 3 11:33:34 EST 2005
Is there any reason WFS getfeatures and describefeaturetype works fine in
4.4.1, but in 4.6.0 no features are returned from getfeatures, and the
describefeaturetype only describes the geometry. The getcapabilities seems
to work ok.
I can see MS making the SQL calls in the PostGIS DB (4.6.0 is much different
than 4.4.1), and it looks as if its getting the four geometries ok ( I run
the SQL it issued and get the four rows back )
The only place I see it getting attribute data it issues:
DECLARE mycursor2 BINARY CURSOR FOR SELECT
ection(force_2d(the_geom)),'NDR') from xxxx WHERE name = 0
There isn't a row with name = 0 in the table, so it will not get any rows,
but maybe all its after is data types?
The 4.4.1 version gets the geometry and oid, then loops through each oid
getting attribute, geom data:
ection(force_2d(the_geom)),'NDR') from xxxx WHERE OID = 13350367
In case its useful, an almost identical map file works correctly, the table
has different columns and the SRID is 4326 not 32615.
Thanks for any suggestions,
Drew.
MapServer version 4.4.1 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT INPUT=TIFF INPUT=EPPL7 INPUT=POSTGIS
INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
MapServer version 4.6.0 OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP OUTPUT=SVG
SUPPORTS=PROJ SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=THREADS INPUT=TIFF
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG
# Start of map file
NAME DEMO
STATUS ON
SIZE 600 600
EXTENT 806141.887843 3346695.719558 810886.158231 3350349.755389
UNITS meters
SHAPEPATH "data"
IMAGECOLOR 255 255 255
DEBUG ON
# you may need to change this to match your MapServer build
IMAGETYPE png_rgb
# Projection definition, consult the PROJ.4 documentation for parameter
discussion
PROJECTION
"init=epsg:32615"
END
# PROJECTION
OUTPUTFORMAT
NAME png_rgb
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGB
EXTENSION "png"
END
# Start of web interface definition (including WMS enabling metadata)
WEB
IMAGEPATH "/var/www/ssl/html/scratch/"
IMAGEURL "scratch/"
METADATA
"wfs_title" "WFS for xxx"
"wfs_onlineresource" "https://www.xxx.xxx..."
"wfs_srs" "EPSG:32615"
"ows_schemas_location" "http://ogc.dmsolutions.ca"
END
END
# Start of symbol definitions (we're only using a few)
SYMBOL
NAME 'circle'
TYPE ELLIPSE
POINTS 1 1 END
FILLED TRUE
END
# Start of layer definitions
LAYER
NAME "xxxx"
#STATUS OFF
STATUS ON
TYPE POLYGON
DUMP TRUE
CONNECTIONTYPE postgis
CONNECTION "user=xxx password=xxx dbname=xxx host=xxx port=5432"
DATA "the_geom from xxxx"
#TEMPLATE "/var/www/ssl/html/xxx"
#TOLERANCE 10
#TOLERANCEUNITS meters
PROJECTION
"init=epsg:32615"
END
METADATA
"wfs_title" "xxxx"
"wfs_abstract" "xxxx"
"wfs_keywordlist" "xxxx"
END
END
END
TABLE DEFINITION
Column | Type | Modifiers
name | character(24) | not null
description | character varying(256) |
the_geom | geometry |
an_int | integer |
comments | character varying |
Indexes:
"xxxx_pkey" primary key, btree (name)
Check constraints:
"$1" CHECK (srid(the_geom) = 32615)
"$2" CHECK (geometrytype(the_geom) = 'MULTIPOLYGON'::text OR the_geom IS
NULL)
