Mapserver and Postgis
Ezequias Rodrigues da Rocha ezequias at RECIFE.PE.GOV.BR
Fri Nov 4 07:09:16 EST 2005
My pg_hba.conf is here:
host    all         all         10.0.0.0 255.0.0.0    password
host    all         all         192.168.0.0 255.0.0.0 password
host    all         all         127.0.0.1/32          trust
host    all         all         200.249.133.135 255.255.255.255
password
# IPv6 local connections:
host    all         all         ::1/128               trust
host    all         all         192.168.0.0 255.255.0 0 password
What do you say about that ?
Frans Knibbe wrote:
> Hello Ezequias,
> Did you edit pg_hba.conf to allow non-local connections to your database?
> Regards,
> Frans
> Ezequias Rodrigues da Rocha wrote:
>> Hi list,
>> I am starting with mapserver, but have a very important error and I
>> have no idea how to put it to work. I doesn't even know if I did it
>> before but here is the problem:
>> I am trying to access a postgis layer with the mapserver 4.4.2 and
>> via browser the return of server was:
>> msDrawMap(): Image handling error. Failed to draw layer named 'bairros'.
>> msPOSTGISLayerOpen(): Query error. couldnt make connection to DB with
>> connect string 'user=postgres password=post dbname=dbpotgis
>> host=192.168.0.15 port=5432'.
>> Error reported was 'could not create socket: Permission denied '.
>> This error occured when trying to make a connection to the specified
>> postgresql server.
>> Most commonly this is caused by
>> (1) incorrect connection string
>> (2) you didnt specify a 'user=...' in your connection string
>> (3) the postmaster (postgresql server) isnt running
>> (4) you are not allowing TCP/IP connection to the postmaster
>> (5) your postmaster is not running on the correct port - if its not
>> on 5432 you must specify a 'port=...'
>> (6) the security on your system does not allow the webserver (usually
>> user 'nobody') to make socket connections to the postmaster
>> (7) you forgot to specify a 'host=...' if the postmaster is on a
>> different machine
>> (8) you made a typo
>> I hope someone could help me. Nobody did before.
>> Sincerely
>> Ezequias
http://ezequiasrocha.blogspot.com
msn:ezequias at hotmail.com
