Google maps projections..
Steve Young
steve at SIERRACLUB.BC.CA
Mon Nov 7 17:04:18 EST 2005
Hi Dave,
Did you remember to change the EXTENT in your map file? It needs to be
in metres for Mercator.
Steve
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Dave Brown
Sent: Monday, November 07, 2005 9:29 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Google maps projections..
Tried using that projection in the top MAP section of the .MAP file,
then put PROJECTION "AUTO"
END
In each layer section, strangely now the maps don't show anything.
When I don't specify any map projection settings, I get it to show in
rougly the correct position just slightly warped.. As soon as I start
trying to change the projections I get nothing. Sadly I was hoping it
was going to be quite straightforward this problem... :(
From: John Hagstrand [mailto:john.hagstrand at INTERAGERESEARCH.COM]
Sent: 07 November 2005 07:07
To: MAPSERVER-USERS at LISTS.UMN.EDU; Dave Brown
Subject: Re: Google maps projections..
Hi Dave,
The list provided me with this projection info a couple weeks ago. I am
using it successfully to draw mapserv images which overlay on top of
Google maps.
PROJECTION
"proj=merc"
"lat_ts=0.0"
"lon_0=-90.0"
"x_0=0.0"
"y_0=0.0"
"ellps=GRS80"
"no_defs"
END
John
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.12.7/159 - Release Date:
02/11/2005
No virus found in this outgoing message.
02/11/2005
