Google maps projections..
Dave Brown dave at DBWS.NET
Mon Nov 7 17:08:08 EST 2005
I didn’t, no..  But that makes a lot of sense , thanks very much :-)  I'll
post with my result.
-----Original Message-----
From: Steve Young [mailto:steve at sierraclub.bc.ca]
Sent: 07 November 2005 22:04
To: Dave Brown; MAPSERVER-USERS at LISTS.UMN.EDU
Subject: RE: [UMN_MAPSERVER-USERS] Google maps projections..
Hi Dave,
Did you remember to change the EXTENT in your map file? It needs to be in
metres for Mercator.
Steve
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Dave Brown
Sent: Monday, November 07, 2005 9:29 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] Google maps projections..
Tried using that projection in the top MAP section of the .MAP file, then
put PROJECTION  "AUTO"
END
In each layer section, strangely now the maps don't show anything.
When I don't specify any map projection settings, I get it to show in rougly
the correct position just slightly warped..  As soon as I start trying to
change the projections I get nothing.  Sadly I was hoping it was going to be
quite straightforward this problem... :(
From: John Hagstrand [mailto:john.hagstrand at INTERAGERESEARCH.COM]
Sent: 07 November 2005 07:07
To: MAPSERVER-USERS at LISTS.UMN.EDU; Dave Brown
Subject: Re: Google maps projections..
Hi Dave,
The list provided me with this projection info a couple weeks ago.  I am
using it successfully to draw mapserv images which overlay on top of Google
maps.
  PROJECTION
    "proj=merc"
    "lat_ts=0.0"
    "lon_0=-90.0"
    "x_0=0.0"
    "y_0=0.0"
    "ellps=GRS80"
    "no_defs"
  END
John
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.1.362 / Virus Database: 267.12.7/159 - Release Date:
02/11/2005
No virus found in this outgoing message.
02/11/2005
Version: 7.1.362 / Virus Database: 267.12.7/159 - Release Date: 02/11/2005
