A little help please
Richard Orth - osmoGIS Incorporated
rco at OSMOGIS.COM
Mon Nov 7 23:29:50 EST 2005
An initialization string must come from somewhere. It tells the service
where to start, which map file to use, layers to start with, etc. For
auto-starting your map service you have at least two options.
1. A javascript redirector. just place the following code in its own file:
<pre>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<html>
<head>
<title>Welcome to ...</title>
<script type="text/javascript" language="JavaScript">
function DoMe() {
document.location = "/cgi-bin/mapserv.exe?" +
"zoomsize=2&layer=tidestations&layer=countries&layer=states&map=c:\inetpub\wwwroot\mapdocs\tester.map";
</script>
</head>
<body onload="DoMe()">
<h1>One moment please...<br>Page Loading</h1>
</body>
</html>
</pre>
2. An HTML only solution. Just change the width and height values to fit
your service.
<html>
<head>
</head>
<iframe width=600 height=400
src="/cgi-bin/mapserv.exe?zoomsize=2&layer=tidestations&layer=countries&layer=states&map=c:\inetpub\wwwroot\mapdocs\tester.map"></iframe>
</body>
</html>
</pre>
Hope this helps
Richard C Orth
Gary Watry wrote:
> Here is a development site I am working on,
> I have borrows button icons from Canada, and most of the borrowed code
> comes from the tutorials, or is noted in the source code.
> http://indianocean.coaps.fsu.edu/httpdocs/tester.html
> The two issues are sort of related.
> 1. I would like to have just one page, so I don’t have the
> initialization page like I currently do. What is this done in and
> where does the initialization code from tester.html go? Does it get
> put into the tester1.html file?
> 2. I want to put the little clip or animation that tells people to
> wait while the program maps are loading. For example like on the
> Canadian site
> http://atlas.gc.ca/site/english/maps/environment/naturalhazards/majorforestfires
> Any thoughts would be appreciated?
> I am a GIS user/administrator getting into Open Source programming and
> can use any help I can get
> Thanks
> ______________________________________________________________
> Gary L. Watry
> GIS Coordinator
> Center for Ocean-Atmospheric Prediction Studies
> FSU / COAPS
> Johnson Building, RM 215
> 2035 East Paul Dirac Drive
> Tallahassee, Florida 32306-2840
> E-Mail: watry at coaps.fsu.edu <mailto:watry at coaps.fsu.edu>
