.map within a .map
Frank Warmerdam
warmerdam at POBOX.COM
Tue Nov 8 10:00:18 EST 2005
On 11/8/05, Oliver Ishmael <oliver_ishmael at hotmail.com> wrote:
> Hi all,
> Is it possible to call a nested .map file within a mapfile.
> For example, i am developing a mapserver for work and have some of the data
> at home, but not the raster data for example. To enable me to easily run and
> edit the mapfile from home, it would be useful if some of this data could be
> called in a separate mapfile, (which i could comment out as necessary).
> What is the syntax for calling a .map file from within a .map file.
Olly,
You might want to talk to Tamas about the work he did
to allow another .map to be used as a raster layer. There
is some description in:
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1445
This isn't incorporated into the mainline MapServer at this point
but it might be if we felt there was a strong enough desire for it.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
