How to show lines between PostGIS data of type POINT
Russ Bradford
Russ.Bradford at CSIRO.AU
Tue Nov 8 22:41:49 EST 2005
Hi list,
I too have a database filled with point data for which I would like
to "join-the-dots". Would anyone have a working example of how to do this
using MapServer and PostgreSQL that they would like to share? The original
thread here mentioned looking into Collect(), MakeLine() and AddPoint(). I
have searched through the documentation and come up blank with all except
Collect(). And being very new to MapServer (and PostgreSQL) I would like a
little more direction in how to apply these solutions. If it makes any
difference, I am using a Windows machine with Apache and the latest
version of Mapserver.
Cheers, Russ.
On Tue, 26 Jul 2005 08:50:52 -0500, David Bitner <osgis.lists at GMAIL.COM>
wrote:
>To show lines but query points, you would need to have your data in
>Mapserver as both lines and points. To convert your points to lines
>in Postgis (can be done on the fly) look into Collect(), MakeLine(),
>and AddPoint(). You'll need to be sure to order your points by
>timestamp before aggregating them to the line.
>On 7/26/05, Sebastian Albrecht <albrecht at fielax.de> wrote:
>> Hello,
>> is it possible to show lines between POINT data results from a
>> PostGIS-DB? Is it possible to somehow convert one point and the next
>> one following to a line on-the-fly each time the Mapserver queries the
>> database?
>> My problem is I have a lot of single latlon points which have
>> different timestamps and further values. The user should be able to
>> query these values of a single point but lines should be shown in the
>> map. Using a LINE type would not be very consistent because the user
>> would not know which end of the line is the point the values belong
>> to.
>> One knows something? ;)
>> Best regards,
>> Sebastian
