Problem using tileindex for time dimension
Paul Tildesley
Paul.Tildesley at CSIRO.AU
Tue Nov 8 22:46:59 EST 2005
I am trying to implement a layer with a time dimension in MapServer to
serve a set of raster images covering 6 months.
I have created a tile index that looks like this:
INFO: Open of `tindex.shp'
using driver `ESRI Shapefile' successful.
Layer name: tindex
Geometry: Polygon
Feature Count: 91
Extent: (79.969000, -65.015900) - (190.057000, 10.044100)
Layer SRS WKT:
(unknown)
time_stamp: String (8.0)
OGRFeature(tindex):0
location (String) = SSTcomp10d_Aasia_2002_1_1_0.tif
time_stamp (String) = 20020101
POLYGON ((79.96900000 10.04410000,190.05700000
10.04410000,190.05700000 -65.01590000,79.96900000
-65.01590000,79.96900000 10.04410000))
OGRFeature(tindex):1
location (String) = SSTcomp10d_Aasia_2002_1_11_0.tif
time_stamp (String) = 20020111
OGRFeature(tindex):2
location (String) = SSTcomp10d_Aasia_2002_1_13_0.tif
time_stamp (String) = 20020113
For a total of 90 tiles. I then reference this in my map file as
follows:
LAYER
NAME sst_timeset
TYPE RASTER
TILEINDEX tindex
STATUS ON
METADATA
WMS_TITLE "Australian Region SST January to June 2002"
WMS_ABSTRACT "Sea-surface temperature for the Australian region. Ten
day composites every second day."
WMS_TIMEFORMAT "YYYYMMDD"
WMS_TIMEEXTENT "20020101/20020630"
WMS_TIMEDEFAULT "20020101"
WMS_TIMEITEM "time_stamp"
END
OFFSITE 255 255 255
DUMP TRUE
END
When I access the layer, either with or without specifying a time, I
always get the last tile rendered, which happens to be 20020608 (I am
assuming that the tiles do not need to be in time increasing order).
An example request is:
http://www.marine.csiro.au/mapserver/cgi-bin/mapserv?map=/srv/www/htdocs
/sst/sst_multi.map&VERSION=1.1.1&SERVICE=WMS&REQUEST=GetMap&SRS=EPSG:432
6&FORMAT=image/gif&EXCEPTIONS=application/vnd.ogc.sexml&WIDTH=400&HEIGHT
=250&LAYERS=sst_timeset&TIME=20020401
Does anyone know what I am doing wrong? Any ideas or suggestions would
be appreciated.
Paul.
