Join between Postgis table and Postgresql table
Paul Ramsey
pramsey at REFRACTIONS.NET
Wed Nov 9 14:34:58 EST 2005
No, no, do it on the fly, using the "arbitrary SQL" feature of the
Mapserver PostGIS connector:
DATA "the_geom from (SELECT g.gid, g.the_geom, a.name, a.description
FROM geometries g, attributes a WHERE g.id = a.id) using SRID=4326
using unique gid"
Note you have to have a geometry and unique id in your output result,
and you have to specify the output SRID. Any SQL is valid in between
the (), just make sure you're always outputting a geometry and id.
Paulo
On Nov 9, 2005, at 1:53 AM, Frans Knibbe wrote:
> Hello Carlo,
> If your data do not change much you could join the two tables in
> postgreSQL to make a new table which can be used by MapServer. This
> you will probably have better performance as well.
> Regards,
> Frans
> Carlo Calvino wrote:
>> Hello all of you,
>> I built a spatial database with PostgreSql/PostGis, and imported a
>> shapefile (cities.shp) inside it. So I have a postgresql database
>> with 2
>> tables, one for the geographic data and the other for alphanumeric
>> data.
>> I was able to publish the vector data by MapServer, and I was also
>> able to
>> query it correctly. But...what about querying the vector layer using
>> information from the second table? I need joining the two tables.
>> As far
>> as I know, it is only possible a join between Postgis and a dbf
>> file, not
>> a DBMS. So there are any suggestions?
