WMS client request method
Frank Warmerdam
warmerdam at POBOX.COM
Thu Nov 10 11:23:39 EST 2005
On 11/10/05, J. Parapar <listario at gmail.com> wrote:
> Hi all
> Is it possible to set the WMS client request method to POST? We have
> a layer with a long SLD_BODY parameter and the web server says that
> the request is too long.
Jorge,
I think POST WMS (and other cgi style requests) have been
supported by MapServer for a long time. I will note that it was
only in March 2004 that the code was modified to support
posts without CONTENT_LENGTH, but if you are doing this
from a browser that should not be an issue.
This is really one of the cases where I would encourage you to
"just try it" before asking. If if doesn't work then you can point
out your problem on the list.
When I was at PCI I used to get questions all the time about
whether the software supported a particular format. My answer
was, try "File->Open" on it, did that work?
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
