WMS client request method
Yewondwossen Assefa assefa at DMSOLUTIONS.CA
Thu Nov 10 11:46:22 EST 2005
Hi There,
  There is actually no support of wms client post request in mapserver.
Later,
J. Parapar wrote:
> Frank,
> Thanks for the answer.  My problem is with the layers in the client
> mapfile. We have several wms layers but i do not know how to indicate
> to MapServer to make POST requests to the WMS server (instead of GET
> requests). I have found the wfs_request_method parameter but I did not
> find a "wms_request_method".
> I have made some tests and, as WMS Server, MapServer do supports
> URL-encoded POST request.
> Thanks again,
> Jorge
> 2005/11/10, Frank Warmerdam <warmerdam at pobox.com>:
>>On 11/10/05, J. Parapar <listario at gmail.com> wrote:
>>>Hi all
>>>Is it possible to set the WMS client request method to POST?  We have
>>>a layer with a long SLD_BODY parameter and the web server says that
>>>the request is too long.
>>Jorge,
>>I think POST WMS (and other cgi style requests) have been
>>supported by MapServer for a long time.  I will note that it was
>>only in March 2004 that the code was modified to support
>>posts without CONTENT_LENGTH, but if you are doing this
>>from a browser that should not be an issue.
>>This is really one of the cases where I would encourage you to
>>"just try it" before asking.  If if doesn't work then you can point
>>out your problem on the list.
>>When I was at PCI I used to get questions all the time about
>>whether the software supported a particular format.  My answer
>>was, try "File->Open" on it, did that work?
>>Best regards,
>>I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
>>light and sound - activate the windows | http://pobox.com/~warmerdam
>>and watch the world go round - Rush    | Geospatial Programmer for Rent
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax:   (613) 565-0925
