timing map requests
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Fri Nov 11 05:49:35 EST 2005
Try jmeter:
http://jakarta.apache.org/jmeter/
It has good support for sessions, forms and everything you will probably need.
Umberto
On 11/11/05, James Lindstorff <jlindstorff at gmail.com> wrote:
> We use a web application stress tool link
> MS WAST
> http://www.microsoft.com/downloads/details.aspx?FamilyID=E2C0585A-062A-439E-A67D-75A89AA36495&displaylang=en
> You can of cause use other stress tools.
> The way we use it is finding a fitting number of URL's and then
> running the stress test after easy change we make to either setup or
> data sources.
> This way we have hard data to back our decisions in changes and optimizations.
> On 11/11/05, Xin <crazygecko at gmail.com> wrote:
> > Hi,
> >  I'm optimising a map at the moment as it takes a while to load.  I thought
> > it would be great having an objective number telling me how long a map took
> > to process, rather than just me feeling how the speed has changed.  I had a
> > good look around in template reference and past posts and wasn't able to
> > find anything.  Does anyone know of a way to do this?  I'm using MapServer
> > CGI so would prefer a non-php way, perhaps javascript.  I might use php if
> > need to.
> >  Really appreciate any input.
> >  Cheers,
> >  Xin
