timing map requests
Xin
crazygecko at GMAIL.COM
Fri Nov 11 08:03:30 EST 2005
Cool, thanks for the replies guys. I'll try those out.
On 11/11/05, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> Try jmeter:
> http://jakarta.apache.org/jmeter/
> It has good support for sessions, forms and everything you will probably
> need.
> Umberto
> On 11/11/05, James Lindstorff <jlindstorff at gmail.com> wrote:
> > We use a web application stress tool link
> > MS WAST
> http://www.microsoft.com/downloads/details.aspx?FamilyID=E2C0585A-062A-439E-A67D-75A89AA36495&displaylang=en
> > You can of cause use other stress tools.
> > The way we use it is finding a fitting number of URL's and then
> > running the stress test after easy change we make to either setup or
> > data sources.
> > This way we have hard data to back our decisions in changes and
> optimizations.
> > On 11/11/05, Xin <crazygecko at gmail.com> wrote:
> > > Hi,
> > > I'm optimising a map at the moment as it takes a while to load. I
> thought
> > > it would be great having an objective number telling me how long a map
> took
> > > to process, rather than just me feeling how the speed has changed. I
> had a
> > > good look around in template reference and past posts and wasn't able
> to
> > > find anything. Does anyone know of a way to do this? I'm using
> MapServer
> > > CGI so would prefer a non-php way, perhaps javascript. I might use php
> if
> > > need to.
> > > Really appreciate any input.
> > > Cheers,
> > > Xin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051111/dc5e723f/attachment.html
