Box on reference map
Stephen Davies
sdc at SDC.COM.AU
Fri Nov 11 21:23:58 EST 2005
Sorry, I got it wrong in my last post.
The only combination of extents that works for all options is to have
main map extents in lat/long (matching the data) and the reference map
extent in the corresponding projection metres.
With this (and only this) combination I can pan on the main map using
the pan icons and by clicking the reference mapand, use a rubber band
to select a box of interest and have it zoom on the main map and
display on the reference map and query points by switching to query
mode.
Dynamically setting reference map image and extent remains a challenge.
Cheers,
Stephen Davies
This email is for the person(s) identified above, and is confidential to
the sender and the person(s). No one else is authorised to use or
disseminate this email or its contents.
Stephen Davies Consulting Voice: 08-8177 1595
Adelaide, South Australia. Fax: 08-8177 0133
Computing & Network solutions. Mobile:0403 0405 83
Name: not available
Desc: signature
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051112/76c8b583/attachment.bin
