performance tuning annotation layers
Erki Saluveer
erki.saluveer at REGIO.EE
Mon Nov 14 06:01:54 EST 2005
Hello Xin,
I had a problem with performance issue when I had to use labeling for a
dense road network. I discovered that outlining takes a lot of time. My test
showed:
without labels ->0,18 sec
with labels -> 0,54 sec
with outlined labels ->1,45 sec
I got some help from Julien-Samuel Lacroix
<http://lists.umn.edu/cgi-bin/wa?A2=ind0506&L=mapserver-users&D=0&I=-3&X=79E
B134332FA237EE4&Y=erki.saluveer%40regio.ee&P=48374> .
He answered in Mapserver-user list:
The reason mapserver outlining is slower is that the outline is made by
drawing the label 8 more times. To do a good outline, mapserver have to
draw the label in all 8 directions in the color of the outline and then
draw the label in the good color at the right place. This gives a
perfect 1 pixel outline.
Even if it seems inefficient, this is what is suggest on the freetype
mailing-list.
In bug 1243, there's 3 patch to use the freetype outlining options. It
use a development version of freetype, though. The official release does
not include this functionality.
See the bug for more details.
http://mapserver.gis.umn.edu/bugs/show_bug.cgi?id=1243
You have extra shadowing that is probably also taking a time.
Greetings,
Erki
_____
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Xin
Sent: Monday, November 14, 2005 12:21 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] performance tuning annotation layers
I'm currently trying to produce my map under 1 second. A tough goal, yes.
I've managed to speed it up from around 3s to 1.5s so far. I did this using
various techniques, such as tileindexing, splitting up data, thinning data.
Using shp2img I can see drawing label cache takes the most time! Close to a
second. Clearly there's some performance to be squeezed out here. I thought
I'd email for some advice. Here's what most of my labels look like:
LABEL
TYPE TRUETYPE
FONT "arial"
FORCE true
SIZE 9
POSITION CR
MINDISTANCE 300
MAXSIZE 20
COLOR 0 0 0
OUTLINECOLOR 255 255 255
SHADOWCOLOR 255 255 255
SHADOWSIZE 2 2
ANTIALIAS false
PARTIALS FALSE
END
I notice if I'm using a bold font, they take quite some time longer. Any
suggestions?
Cheers,
Xin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051114/20f75330/attachment.html
