ECW on mapserver4.6
Frank Warmerdam warmerdam at POBOX.COM
Mon Nov 14 09:16:52 EST 2005
On 11/14/05, almudena rueda <almudenarueda at inicia.es> wrote:
> Hello all,
> I'm using php Mapserverscript and I'm trying to upgrade from Mapserver 4.4
> to Mapserver 4.6, everythng works well except the ecw files that makes a
> memory error when I try to show that kind of layers. I'm working in Windows
> XP with Apache, and using phpMapscript dll. Does anyone know if I have to
> change anything on my .map file to use Mapscript 4.6, or what can I do to
> make the updgrade?
> Here is my ECW raster layer:
Almudena,
There is nothing apparently wrong with your LAYER definition.
When you upgraded to MapServer 4.6 where did you get your
ECW support?   I would encourage you to use the latest version
of the ECW SDK and GDAL 1.3.1.  If you downloaded binary
packages from somewhere, then please indicate where and we
might be able to reproduce the problem.  Otherwise there isn't
much that can be done to help.
Best regards,
