JavaMapScript
Roger Bixby
roger at ROGERBIXBY.COM
Mon Nov 14 23:04:22 EST 2005
Hi all,
I'm trying to use the JavaMapScript package and have run into some difficulty.
When I run the DrawMap test file included with the distribution I get two
different errors.
This first error I get when I reference a map file that is not in the same
directory as the java class file:
C:\eclipse\workspace\tekmaps\.deployables\tekmaps\WEB-INF\classes>java
-Djava.library.path=c:/mapscript -cp
.;c:/tekmaps/mapscript/debug/java/mapscript.jar DrawMap example1-8.map map.jpg
Exception in thread "main" java.lang.UnknownError: No such file or directory
at edu.umn.gis.mapscript.mapscriptJNI.new_mapObj(Native Method)
at edu.umn.gis.mapscript.mapObj.<init>(mapObj.java:328)
at DrawMap.main(DrawMap.java:34)
The second is slightly different, but I suspect it's related to the first:
If I put the map file, in this case example1-8.map in the classpath, I sometimes
get a java IOException:
(example1-8.map)java.io.IOException: (example1-8.map)
I can't find any documentation on these errors at all. What little documentation
I have been able to find is a couple of years old. Is there anyone out there now
using Java MapScript who can steer me in the right direction with this?
Thanks,
Roger Bixby
