where is my polygons?
Sergey Fedutov
fedutov at MAIL.RU
Tue Nov 15 05:47:47 EST 2005
Hi!
I need to render map with buildings layers. (See
http://getart.ru/~katsay/tile1.png) and all work fine.
But, if i expand map Extent up to 20 meters i always get absent some
polygons. (see http://getart.ru/~katsay/tile2.png)
Map scale about 1:10000. (on bigger scales 1:25000, 1:50000 all works fine).
Layer data stored in WGS84 projection and reprojecting to UTM (esri:53004).
I try render layer from PostGis and shapefile, i try modify layer data to
close all unclosed polygons. (Via FME Suite). But always get same results
with buildings layer.
Note, major roads (polygons too) rendering is allways perfect. I use
mapserver 4.6.0 via phpMapscript.
Whats wrong? Any ideas?
Thanks.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051115/f4972b29/attachment.html
