NetCDF in Mapserver...
Andrea Marelli maro.jam at TISCALI.IT
Thu Nov 17 04:03:10 EST 2005
Hi Norman,
Thanks very much for your help and for your hints..
I've tried to change my mapfile as you said, but nothing change...
I can't see anything yet..
(the tif image that mapserv create is all black)
Now, my mapfile is:
#### map file #####
MAP
NAME "Test"
EXTENT 22 -20 75 45
SIZE 600 600
SHAPEPATH "/raid/emis/satellite_test"
IMAGECOLOR 235 225 225
OUTPUTFORMAT
   NAME GEOTIFF_FLOAT
   DRIVER "GDAL/GTiff"
   MIMETYPE "image/tiff"
   IMAGEMODE FLOAT32
   EXTENSION "tif"
END
LAYER
   NAME "layertest"
   STATUS DEFAULT
   TYPE RASTER
   DUMP TRUE
   DATA "N20001832000213_MO.ncdf"
   PROCESSING "BANDS=3"
   PROCESSING "SCALE=AUTO"
      METADATA
            wcs_label "Test netCDF Server"
            ows_extent '22 -20 75 45'
            wcs_resolution '0.04388924 0.04387414'
            ows_srs "EPSG:4326"
            wcs_formats "GEOTIFF_FLOAT"
            wcs_nativeformat "netCDF"
            wcs_bandcount "2"
            wcs_rangeset_axes "lon"
            wcs_rangeset_label "Atmospheric Levels"
            wcs_rangeset_name "chlor_a"
       END
TEMPLATEPATTERN 'template*'
WEB
    TEMPLATE  'template.php'
    IMAGEPATH 'pippo/'
    IMAGEURL  '/pippo/'
END
END
END
#### end map file #####
Is it correct?
What should i have to put in wcs_rangeset_axes and wcs_rangeset_name?
i'm not sure about them..
Another question.
Does the outputformat image must be Geotiff (if the input data is NetCDF) or
can it be a more simple format as gif or jpeg?
Thanks,
Andrea
