NetCDF in Mapserver...
Norman Barker
nbarker at RSINC.COM
Thu Nov 17 04:19:53 EST 2005
-----Original Message-----
From: Andrea Marelli [mailto:maro.jam at TISCALI.IT]
Sent: Thursday, November 17, 2005 9:03 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU; Norman Barker
Subject: Re: NetCDF in Mapserver...
Hi Norman,
Thanks very much for your help and for your hints..
I've tried to change my mapfile as you said, but nothing change...
I can't see anything yet..
(the tif image that mapserv create is all black)
Now, my mapfile is:
#### map file #####
MAP
NAME "Test"
EXTENT 22 -20 75 45
SIZE 600 600
SHAPEPATH "/raid/emis/satellite_test"
IMAGECOLOR 235 225 225
OUTPUTFORMAT
NAME GEOTIFF_FLOAT
DRIVER "GDAL/GTiff"
MIMETYPE "image/tiff"
IMAGEMODE FLOAT32
EXTENSION "tif"
END
LAYER
NAME "layertest"
STATUS DEFAULT
TYPE RASTER
DUMP TRUE
DATA "N20001832000213_MO.ncdf"
PROCESSING "BANDS=3"
PROCESSING "SCALE=AUTO"
METADATA
wcs_label "Test netCDF Server"
ows_extent '22 -20 75 45'
wcs_resolution '0.04388924 0.04387414'
ows_srs "EPSG:4326"
wcs_formats "GEOTIFF_FLOAT"
wcs_nativeformat "netCDF"
wcs_bandcount "2"
wcs_rangeset_axes "lon"
wcs_rangeset_label "Atmospheric Levels"
wcs_rangeset_name "chlor_a"
END
TEMPLATEPATTERN 'template*'
WEB
TEMPLATE 'template.php'
IMAGEPATH 'pippo/'
IMAGEURL '/pippo/'
END
END
END
#### end map file #####
Is it correct?
What should i have to put in wcs_rangeset_axes and wcs_rangeset_name?
i'm not sure about them..
Another question.
Does the outputformat image must be Geotiff (if the input data is NetCDF) or
can it be a more simple format as gif or jpeg?
Thanks,
Hi Andrea,
it looks like you are confusing MapServer WCS mapfile notation and WMS notation, for a WCS (a way of serving raw coverage data, such as that in netCDF) you don't need to put processing directives. For a WMS you do need the processing directives to produce a picture (Map).
Is this server online? I will try to access it for you. If you can send me a netCDF file I can put it through our system and send you the mapfile if you want, then you will only have to change the data path location.
Norman
