Csharp/MapScript
Abe Gillespie
abe.gillespie at GMAIL.COM
Thu Nov 17 15:06:53 EST 2005
Tamas,
Isn't there still tremendous threading issues that cause endless
problems when hosted in ASP.NET? Or has that been solved ... or have
people found work-arounds?
Thanks.
-Abe
On 11/17/05, Tamas Szekeres <szekeres.tamas at freemail.hu> wrote:
> I recommend to compile mapserver and the related libraries for yourself
> before using them with ASP.NET. It is highly suggested to use the same
> compiler version for theese packages (eg VS 2003).
> The Win32 compilation instructions can be found at:
> http://mapserver.gis.umn.edu/doc46/win32_compile-howto.html
> to compile use Visual Studio .NET Command Prompt and nmake.
> To compile mapscript:
> 1. download the latest SWIGWin package which contains the Win32 binary
> SWIG.EXE
> 2. edit nmake.opt for referring to the SWIG location
> 3. In Visual Studio .NET Command Prompt cd to mapscript/csharp
> 4. nmake -f makefile.vc
> To test the compilation
> 5. Create an empty ASP.NET C# project
> 6. Add reference to the previously compiled mapscript_csharp.dll
> 6. Use the following code to test the map creation
> private void Page_Load(object sender, System.EventArgs e)
> // Put user code to initialize the page here
> using (mapObj map = new mapObj(@"C:\Maps\MapFiles\mymap.map"))
> using(imageObj image = map.draw())
> byte[] img = image.getBytes();
> Response.BinaryWrite(img);
> 7. Before testing the project make sure that all of the dlls (depending on
> the mapserver compiler options, eg: bgd.dll, gdal13.dll, libcurl.dll,
> libmap.dll, mapscript.dll, mapscript_csharp.dll, proj.dll) reside in the
> correct location. I recommend to place the dll-s to the same directory as
> your target file.
> Best Regards,
> Tamas Szekeres
> On Tue, 15 Nov 2005 13:08:06 -0600, Suman G. Pradhan
> <sgp_dgtek at HOTMAIL.COM> wrote:
> >Dear all
> >Please some one help me finding Csharp/MapScript.
> >Why there is no resources related with MapServer and .Net ?
