Csharp/MapScript
Ian Erickson
ierickson at ANALYGIS.COM
Thu Nov 17 15:18:33 EST 2005
I'd like to know the answer to this as well...are there things that we
can do that would promote thread safety - like building MapServer
without GDAL support?
- Ian
Abe Gillespie wrote:
>Tamas,
>Isn't there still tremendous threading issues that cause endless
>problems when hosted in ASP.NET? Or has that been solved ... or have
>people found work-arounds?
>Thanks.
>-Abe
>On 11/17/05, Tamas Szekeres <szekeres.tamas at freemail.hu> wrote:
>>I recommend to compile mapserver and the related libraries for yourself
>>before using them with ASP.NET. It is highly suggested to use the same
>>compiler version for theese packages (eg VS 2003).
>>The Win32 compilation instructions can be found at:
>>http://mapserver.gis.umn.edu/doc46/win32_compile-howto.html
>>to compile use Visual Studio .NET Command Prompt and nmake.
>>To compile mapscript:
>>1. download the latest SWIGWin package which contains the Win32 binary
>>SWIG.EXE
>>2. edit nmake.opt for referring to the SWIG location
>>3. In Visual Studio .NET Command Prompt cd to mapscript/csharp
>>4. nmake -f makefile.vc
>>To test the compilation
>>5. Create an empty ASP.NET C# project
>>6. Add reference to the previously compiled mapscript_csharp.dll
>>6. Use the following code to test the map creation
>>private void Page_Load(object sender, System.EventArgs e)
>>// Put user code to initialize the page here
>> using (mapObj map = new mapObj(@"C:\Maps\MapFiles\mymap.map"))
>> using(imageObj image = map.draw())
>> byte[] img = image.getBytes();
>> Response.BinaryWrite(img);
>>7. Before testing the project make sure that all of the dlls (depending on
>>the mapserver compiler options, eg: bgd.dll, gdal13.dll, libcurl.dll,
>>libmap.dll, mapscript.dll, mapscript_csharp.dll, proj.dll) reside in the
>>correct location. I recommend to place the dll-s to the same directory as
>>your target file.
>>Best Regards,
>>Tamas Szekeres
>>On Tue, 15 Nov 2005 13:08:06 -0600, Suman G. Pradhan
>><sgp_dgtek at HOTMAIL.COM> wrote:
>>>Dear all
>>>Please some one help me finding Csharp/MapScript.
>>>Why there is no resources related with MapServer and .Net ?
