A little help please
Richard Orth - osmoGIS Incorporated
rco at OSMOGIS.COM
Thu Nov 17 18:51:52 EST 2005
Having it on your server helped diagnose. The url had [program] in it.
If you replace the line below in the javascript it should work. Now it
will know what program to call
document.location = "/cgi-bin/mapserv.exe?" +
"program=/cgi-bin/mapserv.exe&zoomsize=2&layer=tidestations&layer=countries&layer=states&map=c:\inetpub\wwwroot\mapdocs\tester.map";
Richard C Orth
Gary Watry wrote:
>Hi Rich
>Here is where I am at, If you can give me any ideas.
>The working site is
>http://indianocean.coaps.fsu.edu/httpdocs/indextest.html
>If I use indextest.html to initialize tidestationtest.html with a mouse
>click it all works
>If I use test2.html(your script) I get further than I did in the past but
>the only button that works is the help button, anywhere else and I get the
>"The page cannot be found" error, I don't believe it is a IIS issue or the
>first way should not work.
>Am I missing something (like a var or piece of code) in the initialization
>of tidestationtest.html that is in the Indextest.html but not present if I
>try auto initialization.
>______________________________________________________________
>Gary L. Watry
>GIS Coordinator
>Center for Ocean-Atmospheric Prediction Studies
>FSU / COAPS
>Johnson Building, RM 215
>2035 East Paul Dirac Drive
>Tallahassee, Florida 32306-2840
>E-Mail: watry at coaps.fsu.edu
>-----Original Message-----
>From: Richard Orth - osmoGIS Incorporated [mailto:rco at osmoGIS.com]
>Sent: Thursday, November 17, 2005 2:14 PM
>To: Gary Watry; MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] A little help please
>It may be fouling because of the full path. Try using
>map=mapdocs\tester.map
>or the same path used for the template in your .map file.
>I don't think its an IIS specific problem because I tested both on IIS
>Hope this helps.
>Richard C Orth
>Gary Watry wrote:
>>I tried both the Javascript and Html only solution. The javascript works
>>better and it does open a image of the site but when I click on any of the
>>buttons I get
>>The page you are looking for might have been removed, had its name changed,
>>or is temporarily unavailable.
>>Please try the following:
>> * Make sure that the Web site address displayed in the address bar of
>>your browser is spelled and formatted correctly.
>> * If you reached this page by clicking a link, contact the Web site
>>administrator to alert them that the link is incorrectly formatted.
>> * Click the Back button to try another link.
>>HTTP Error 404 - File or directory not found.
>>Internet Information Services (IIS)
>>I assume this is an IIS problem, any suggests?
>>On Mon, 7 Nov 2005 23:29:50 -0500, Richard Orth - osmoGIS Incorporated
>><rco at OSMOGIS.COM> wrote:
>>>An initialization string must come from somewhere. It tells the service
>>>where to start, which map file to use, layers to start with, etc. For
>>>auto-starting your map service you have at least two options.
>>>1. A javascript redirector. just place the following code in its own file:
>>><pre>
>>><meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
>>><html>
>>><head>
>>><title>Welcome to ...</title>
>>><script type="text/javascript" language="JavaScript">
>>>function DoMe() {
>>>"zoomsize=2&layer=tidestations&layer=countries&layer=states&map=c:\inetpub
>>></script>
>>></head>
>>><body onload="DoMe()">
>>><h1>One moment please...<br>Page Loading</h1>
>>></body>
>>></html>
>>></pre>
>>>2. An HTML only solution. Just change the width and height values to fit
>>>your service.
>>><html>
>>><head>
>>></head>
>>><iframe width=600 height=400
>>>src="/cgi-bin/mapserv.exe?zoomsize=2&layer=tidestations&layer=countries&la
>yer=states&map=c:\inetpub\wwwroot\mapdocs\tester.map"></iframe>
>>></body>
>>></html>
>>></pre>
>>>Hope this helps
>>>Richard C Orth
>>>Gary Watry wrote:
>>>>Here is a development site I am working on,
>>>>I have borrows button icons from Canada, and most of the borrowed code
>>>>comes from the tutorials, or is noted in the source code.
>>>>http://indianocean.coaps.fsu.edu/httpdocs/tester.html
>>>>The two issues are sort of related.
>>>>1. I would like to have just one page, so I don't have the
>>>>initialization page like I currently do. What is this done in and
>>>>where does the initialization code from tester.html go? Does it get
>>>>put into the tester1.html file?
>>>>2. I want to put the little clip or animation that tells people to
>>>>wait while the program maps are loading. For example like on the
>>>>Canadian site
>>http://atlas.gc.ca/site/english/maps/environment/naturalhazards/majorforest
>fires
>>>>Any thoughts would be appreciated?
>>>>I am a GIS user/administrator getting into Open Source programming and
>>>>can use any help I can get
>>>>Thanks
>>>>Gary L. Watry
>>>>GIS Coordinator
>>>>FSU / COAPS
>>>>E-Mail: watry at coaps.fsu.edu <mailto:watry at coaps.fsu.edu>
