WMS time YYYY pattern problem
Jeroen Ticheler
Jeroen.Ticheler at FAO.ORG
Fri Nov 18 02:35:32 EST 2005
Thanks! I'm actually running on Mac OS X. Same problems?
Jeroen
On 18 Nov 2005, at 00:03, Yewondwossen Assefa wrote:
> Mapserver used strptime to convert th time to a tm time structure.
> On Linux it uses the system function and on windows there is a
> local copy of the function in mapserver (strptime.c). Cheking the
> local code used for windows, It could have problems with dates
> before 1970.
> Later,
> Jeroen Ticheler wrote:
>> How do I know?
>> Thanks for the quick response!
>> Jeroen
>>>> Also, when requesting 1965 it gives the error that that year is
>>>> out of the series, but the image is actually there.
>>> If Mapserver is converting time to seconds since the epoch
>>> (1970-01-01T00:00:00Z), then 1965 may pose a problem.
>>> -Jeff DLB
> Assefa Yewondwossen
> Software Analyst
> Email: assefa at dmsolutions.ca
> http://www.dmsolutions.ca/
> Phone: (613) 565-5056 (ext 14)
> Fax: (613) 565-0925
