[mapserver] Java VM Crashes using the Mapscript API
Umberto Nicoletti umberto.nicoletti at GMAIL.COM
Fri Nov 18 09:48:18 EST 2005
On 11/18/05, umn-ms at hydrotec.de <umn-ms at hydrotec.de> wrote:
> Hallo Umberto, Fernando, Donovan and ...
> Thanks for coming back to this point. This area is also still a big
> problem to me. (Especially I'm happy about the Java/Oracle-guru-combination
> Fernando/Umberto.)
You are overrating me (blushing)
> It's maybe usefull to figure out where we agree and where we disagree:
> - I disagree to Umberto with the use of the Java-gc in Mapserver 4.6. I
> state:
>   As long as Java/Mapserver is at is is now (Version 4.6.1)
>   one must not rely on gc only. One has to call delete.
I should have pointed out that I was talking about 4.4.2.
In my applications I *never* create mapscript objects except for the
main mapObj (I do not add layers, classes or anything else in Java
code). This should explain why I do not see a reason for calling
delete explicitly.
I have performed extensive profiling (in terms of both concurrent
users and elapsed time) for my apps and memory was efficiently managed
by the VM with no leaks and this convinced me further not to call
delete.
>   To the question of Fernando: "So the question is, where I can call delete?
>   is my rule of thumb:
>    "Call delete on Mapserver-Objects as soon as you can whenever a delete
> exists."
>   As a matter of fact: By doing so, delete is called more often then
> necessary, because
>   in many cases the finaliser would do a good job.  But this doesn't matter.
I would suggest that this affirmation be checked against code because
I am not sure that the swig glue code will always be safe with regard
to double frees. In general I do not see any possible benefit coming
from this behaviour, but I could be wrong.
> - I  agree to Umberto that there is a bug in Java/Mapserver behaviour.
>   My suggestion is obvioulsy not a solution but a way to live with
>   the software as it is.
Which is what we do with most software anyway ;-)
> If we would come to the question "How should Java/Mapserver behave"
> my personal opinion is to look at the way the Eclipse-People made SWT.
> They also had the problem, that Java-Objects enclose ressources which are
> not managed by the Java-VM:
> http://www.eclipse.org/articles/swt-design-2/swt-design-2.html
> (Rule 1: If you created it, you dispose it. )
> Following this approache would leave to only small changes in
> Java/Mapserver-Code
> but to a different documentation of the Java/Mapscript-API and it should be
> clearer
> when a objected has to be delete by the way an object is created.
> (Actually I suppose, that Umberto will disagree in this point  ...  :-) )
In fact I disagree when you say that this requires 'only small
changes', this is a major effort:
- keep in mind that the core swig code is also used by other languages
and to my knowledge in python there is no need to do garbage
collection yourself, so we should write swig glue code especially for
Java.
-all delete methods should be implemented so that they are smart
enough check for null pointers before dereferencing them, to avoid npe
in the gc phase.
- finally there is the enormous problem of global variables in
mapserver sources which make some of it not thread safe.
For the record: I would *love* to be proved wrong and get in exchange
a reasonably safe Java mapscript, even without all whistles and bells
of a mapserver cgi.
> At last it's maybe usefull to share experiences in stability:
> We wrote an Oracle-Spatial/Tomcat/Mapserver-Application
> (Linux-Suse 9.3)
> - On our testsystem it runs very fine for weeks.
>   The testsystem even survives stress-tests, where we simulate some browsers
> making
>   many requests.
> - On the customers (production-)machine we still have Tomcat crashes about
> one or
>    two times the day. We didn't find a solution (except a watchdog-software
> which restarts tomcat in
>    the crash-case :-( )
>    This machine also survives the one- or two-hour stress-tests!
> This happens although I'm quite shure, that we followed the "delete as soon
> as possible"-rule.
BTW: how do you stress test your application (software, configuration, etc)?
Best regards,
Umberto
> Crashes occure often somewhere in the OCI.
> But  I'm not able to be more precise for the moment, because I have very
> restricted access to
> the production-machine and crashes which occure only one or two times a day
> are obviously difficult to analyse.
> (Fernando: That does not necessarily mean, that the Mapserver-Oracle-Code is
> buggy. This
> could be a consecutive fault from some other memory-management-error ...)
> Benedikt
> Umberto Nicoletti <umberto.nicoletti at gmail.com> schrieb am 18.11.2005
> 13:09:38:
>  > On 11/18/05, Fernando Simon <fsimon at univali.br> wrote:
>  > > Hi Benedikt and Umberto,
>  > >     Here I'm working with a project that uses JavaMapscript and I'm
> with
>  > > some stability problems. For the project I use Mapserver (I compiled
>  > > myself, with multi thread support) with just these supports:
>  > > JavaMapscript, Oracle Spatial (I develop the maporaclespatial.c),
> Raster.
>  > >     Sometimes the server (TomCat) crashes in randomly parts of the
> code,
>  > > I suspect that the issue is with Java garbage collector and the delete
>  > > function. In the code I did as Benedict suggested, if I create an
> object
>  > > (like layer, class, style....), after I finished all the operations
> with
>  > > this object I delete it (using delete).
>  > >     But Umberto, wrote, correct me if I'm wrong, that he don't use the
>  > > delete function. So the question is, where I can call delete? For what
>  > > objects can I use delete?
>  > To be exact I wrote:
>  > /quote
>  > [...] this is why I never attempt to
>  > release objects on my own, but I always leave it up to the gc.
>  > Even in that case a segfault is indeed possible and that's why we need
>  > to open an issue on bugzilla so that the developers know.
>  > quote/
>  > So my suggestion is: do not use delete at all, since the jvm will
>  > handle that for you automatically, but remember that this will not
>  > prevent random crashes from happening. The issue is unfortunately
>  > deeply rooted within mapserver, which was not coded for long
>  > multi-threaded operations, but rather for short-lived independent
>  > processes.
>  > To date I have found that Java mapscript can be used to provide basic
>  > mapping services with reasonable stability and performance when only
>  > the following components are involved:
>  > - shape support
>  > - raster support (via gdal)
>  > - proj
>  > In the future I will have to support postgis and that frankly worries me
> a bit.
>  > HTH,
>  > Umberto
>  > >     Regards.
>  > > Fernando Simon
>  > > Mapserver and Oracle Spatial developer
>  > > G10 - Laboratorio de Computacao Aplicada - Brazil
>  > > http://www.univali.br/g10 - UNIVALI/CTTMAR
>  > > Benedikt Rothe wrote:
>  > > > Hallo Umberto and Christian
>  > > > Christian reported a crash in layerObj.delete() which I
>  > > > also detected.
>  > > > I think I understood the following:
>  > > > Let's say, we have an initialized  mapObj mO;
>  > > > layerObj lO = new layerObj(mO);
>  > > > // Say lO is the 5th layer now.
>  > > > // Now lO.swigCMemOwn == true and
>  > > > //     lO.swigCPtr points onto the mO.swigCPtr->layers[4]
>  > > > // now the mapObj is deleted but the Java-layerObj continues to live.
>  > > > // the C-layer-Object mO.swigCPtr->layers[4] will deleted and freed
> also!
>  > > > mO.delete()
>  > > > // From now on O.swigCPtr points into invalid piece of C-memory.
>  > > > Later on the Java-garbage-collector finalizes the layerObj.
>  > > > Because of "lO.swigCMemOwn == true" and "lO.swigCPtr!=0" the
>  > > > finalize-method calls
>  > > > layerObj.delete(). This method frees lO.swigCPtr which is invalid
> memory.
>  > > > Same story about layerObj/classObj.
>  > > > Benedikt Rothe
>  > > > UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
>  > > > 28.06.2005 12:16:01:
>  > > > > Hello Umberto,
>  > > > > Umberto Nicoletti wrote:
>  > > > > >Hi Christian,
>  > > > > >I do not think the error you are getting is due to threading
> issues,
>  > > > > >but trying what Mario suggests will at least narrow the search
> field.
>  > > > > >In case you are still getting errors even with synchronized code
>  > > > > >blocks I have a few questions for you to help me understand your
>  > > > > >setup:
>  > > > > >Do you always get errors in delete_classObj or do the segfaults
> happen
>  > > > > >in different functions?
>  > > > > Yes, the segfaults alway happen in the delete_classObj function.
>  > > > > >If the segfault is always caused by
>  > > > > >delete_ClassObj then I suppose you are creating class objects in
> your
>  > > > > >java code. Is that true?
>  > > > > Yes, that's true, I need to create classObjects.
>  > > > > >If that is the case then we can setup a very simple test to
> reproduce
>  > > > > >the problem: modify one of the examples so that it will load a map
> and
>  > > > > >then start adding classes in similar fashion to your code, but in
> a
>  > > > > >tight loop. Classes should be made eligible for gc by dropping all
>  > > > > >references to them. As soon as gc kicks in the vm should crash. At
>  > > > > >that point it will be clear that the problem is in delete_ClassObj
> and
>  > > > > >the hunting season will be open.
>  > > > > I have tested a proposed solution by Benedikt Rothe yet, which said
> that
>  > > > > one should call the delete method of the classObject after it is
> not
>  > > > > needed any more.
>  > > > > This confirms my assumption that this problem occours when java's
>  > > > > garbage-collector destroys the null-referenced objects. Now it
> seems to
>  > > > > work properly.
>  > > > > The mapserver version we actually use is 4.4.1, we have tested
> 4.4.2,
>  > > > > 4.2.4 and 4.6.0, too before.
>  > > > > Thank you all for your help!
>  > > > > Best Regards,
>  > > > > Christian :-)
>  > > > > >BTW can you report the mapserver version you are using (I have
> 4.4.2
>  > > > > >and I know it works, so if you can use that).
>  > > > > >Best Regards,
>  > > > > >Umberto
>  > > > > >On 6/21/05, Christian Schroeder <mailings at abiwood99.de> wrote:
>  > > > > >>Hello Umberto,
>  > > > > >>thank your for your immediate answer.
>  > > > > >>I do not call the delete_ methody directly and don't think I am
> using
>  > > > > >>special gc parameters.
>  > > > > >>And... I have read the README file before compiling the mapserver
>  > > > > >>I will try to get it to work with "synchronized"-flags als Mario
> Basa
>  > > > > >>supposed.
>  > > > > >>Thank you!
>  > > > > >>Christian
>  > > > > >>Umberto Nicoletti schrieb:
>  > > > > >>>Christian,
>  > > > > >>>are you calling the delete_ methods directly in your code or are
> you
>  > > > > >>>using some special gc paramaters?
>  > > > > >>>As a side note the --use-threads option to configure is
> *absolutely*
>  > > > > >>>necessary, as are brakes on your car. I think we should write it
> in
>  > > > > >>>the README (as if someone actually cared to read it :-( ).
>  > > > > >>>Best regards,
>  > > > > >>>Umberto
>  > > > > >>>On 6/21/05, Sean Gillies <sgillies at frii.com> wrote:
>  > > > > >>>>I'm forwarding this to the users list. Hopefully, Umberto will
>  > > > be able
>  > > > > >>>>to provide some insight.
>  > > > > >>>>cheers,
>  > > > > >>>>Sean
>  > > > > >>>>On Jun 16, 2005, at 5:08 PM, Christian Schr�der wrote:
>  > > > > >>>>>Dear Mr. Gillies,
>  > > > > >>>>>some weeks ago me and Florian Pepping contacted you because we
> had
>  > > > > >>>>>problems using the Java Mapscript API. Thanks to you we could
> solve
>  > > > > >>>>>these problems :-)
>  > > > > >>>>>Now we got our program doing what it's supposed to do but
> there is
>  > > > > >>>>>still a big problem left which we were not able to solve yet:
>  > > > > >>>>>We created a simple servlet which is created inside a Tomcat
> 5.0
>  > > > > >>>>>Webserver. This servlet created a map image (png/jpg) and
> displays
>  > > > > >>>>>some specified objects on the map. (We use it for location
> based
>  > > > > >>>>>services --> "show me the position of the next printer").
>  > > > > >>>>>After an irregular number of calls of our servlet which uses
>  > > > the Java
>  > > > > >>>>>Mapscript API the complete Java VM and with it the Tomcat
>  > > > crashes. I
>  > > > > >>>>>attached the error report below. The program works properly
> for a
>  > > > > >>>>>number of calls (between 5 and 1000 :-) ) and after that it
>  > > > crashes.
>  > > > > >>>>>We have tried several versions of the mapserver (4.4.1, 4.4.2,
>  > > > 4.2.4,
>  > > > > >>>>>4.6.1 RC1) and compiled the Java Mapscript Module with JDK
>  > > > 1.4.2 and
>  > > > > >>>>>1.5.0. We also configured mapserver using the --with-threads
>  > > > option,
>  > > > > >>>>>but all this did not help. By the way the mapserv cgi-module
> works
>  > > > > >>>>>properly.
>  > > > > >>>>>Do you have an idea for this?
>  > > > > >>>>>Thanks for your anxiety
>  > > > > >>>>>Christian & Florian
>  > > > > >>>>>University of Paderborn, Germany
>  > > > > >>>>>JavaMapscriptLoader: mapscript native library has been loaded.
>  > > > > >>>>>* mapscript native library loaded *
>  > > > > >>>>>An unexpected exception has been detected in native code
>  > > > outside the
>  > > > > >>>>>VM.
>  > > > > >>>>>Unexpected Signal : 11 occurred at PC=0x3338268
>  > > > > >>>>>Function=delete_classObj+0x8
>  > > > > >>>>>Library=/usr/lib/libmapscript.so
>  > > > > >>>>>Current Java thread:
>  > > > > >>>>>       at
> edu.umn.gis.mapscript.mapscriptJNI.delete_classObj(Native
>  > > > > >>>>>Method)
>  > > > > >>>>>       at
> edu.umn.gis.mapscript.classObj.delete(classObj.java:32)
>  > > > > >>>>>       at
> edu.umn.gis.mapscript.classObj.finalize(classObj.java:26)
>  > > > > >>>>>       at
> java.lang.ref.Finalizer.invokeFinalizeMethod(Native
>  > > > Method)
>  > > > > >>>>>       at
> java.lang.ref.Finalizer.runFinalizer(Finalizer.java:83)
>  > > > > >>>>>       at
> java.lang.ref.Finalizer.access$100(Finalizer.java:14)
>  > > > > >>>>>       at
> >>>>>java.lang.ref.Finalizer$FinalizerThread.run(Finalizer.java:160)
>  > > > > >>>>>Dynamic libraries:
>  > > > > >>>>>Can not get information for pid = 10558
>  > > > > >>>>>Heap at VM Abort:
>  > > > > >>>>>Heap
>  > > > > >>>>>def new generation   total 1152K, used 135K [0x08ae0000,
>  > > > 0x08c20000,
>  > > > > >>>>>0x08fc0000)
>  > > > > >>>>> eden space 1024K,   0% used [0x08ae0000, 0x08ae4078,
> 0x08be0000)
>  > > > > >>>>> from space 128K, 100% used [0x08c00000, 0x08c20000,
> 0x08c20000)
>  > > > > >>>>> to   space 128K,   0% used [0x08be0000, 0x08be0000,
> 0x08c00000)
>  > > > > >>>>>tenured generation   total 15048K, used 13624K [0x08fc0000,
>  > > > > >>>>>0x09e72000,
>  > > > > >>>>>0x0cae0000)
>  > > > > >>>>>  the space 15048K,  90% used [0x08fc0000, 0x09d0e1c0,
> 0x09d0e200,
>  > > > > >>>>>0x09e72000)
>  > > > > >>>>>compacting perm gen  total 18432K, used 18373K [0x0cae0000,
>  > > > > >>>>>0x0dce0000,
>  > > > > >>>>>0x10ae0000)
>  > > > > >>>>>  the space 18432K,  99% used [0x0cae0000, 0x0dcd1618,
> 0x0dcd1800,
>  > > > > >>>>>0x0dce0000)
>  > > > > >>>>>Local Time = Tue Jun 14 15:32:19 2005
>  > > > > >>>>>Elapsed Time = 246
>  > > > > >>>>># The exception above was detected in native code outside the
> VM
>  > > > > >>>>># Java VM: Java HotSpot(TM) Client VM (1.4.2_08-b03 mixed
> mode)
>  > > > > >>>>># An error report file has been saved as
> /tmp/hs_err_pid10558.log.
>  > > > > >>>>># Please refer to the file for further information.
>  > > > > >>>>>On Mar 22, 2005, at 12:02 PM, Florian Pepping wrote:
>  > > > > >>>>>>Dear Mr. Gillies,
>  > > > > >>>>>>I'm a student of the University of Paderborn in Germany and
>  > > > member of
>  > > > > >>>>>>the project group "Location Based Services for Wireless
>  > > > Devices". In
>  > > > > >>>>>>this project we try to position laptops and other
> WLAN-enabled
>  > > > > >>>>>>devices  using the signal strength of the WLAN. According to
> their
>  > > > > >>>>>>position, we  want to offer location based services to the
> persons
>  > > > > >>>>>>using the devices  (where I am; where's the next printer; is
>  > > > there a
>  > > > > >>>>>>friend nearby)
>  > > > > >>>>>>In order to do this, we want to use your mapserver and the
> Java
>  > > > > >>>>>>Mapscript API to generate maps according to the actual
>  > > > position and
>  > > > > >>>>>>situation. We like to customize the map of our building and
> add
>  > > > > >>>>>>points, lines and so on.
>  > > > > >>>>>>We have been able to compile the whole mapserver and the Java
>  > > > > >>>>>>Mapscript API. A small Java example also works, which
> presents an
>  > > > > >>>>>>unchanged map of our building.
