WMS time YYYY pattern problem
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Nov 18 13:53:33 EST 2005
Not sure. I have check some implementations of strptime.c (although I
could not locate the one used on mac) and I do not seem to see the
limitation in them. You should file a bug on it.
Jeroen Ticheler wrote:
> Thanks! I'm actually running on Mac OS X. Same problems?
> Jeroen
> On 18 Nov 2005, at 00:03, Yewondwossen Assefa wrote:
>> Mapserver used strptime to convert th time to a tm time structure. On
>> Linux it uses the system function and on windows there is a local
>> copy of the function in mapserver (strptime.c). Cheking the local
>> code used for windows, It could have problems with dates before 1970.
>> Later,
>>> How do I know?
>>> Thanks for the quick response!
>>> Jeroen
>>>>> Also, when requesting 1965 it gives the error that that year is
>>>>> out of the series, but the image is actually there.
>>>> If Mapserver is converting time to seconds since the epoch
>>>> (1970-01-01T00:00:00Z), then 1965 may pose a problem.
>>>> -Jeff DLB
>> Assefa Yewondwossen
>> Software Analyst
>> Email: assefa at dmsolutions.ca
>> http://www.dmsolutions.ca/
>> Phone: (613) 565-5056 (ext 14)
>> Fax: (613) 565-0925
Assefa Yewondwossen
Software Analyst
Fax: (613) 565-0925
