geodatabase as ogr datasource
Edwin Knuth
eknuth at GMAIL.COM
Fri Nov 18 14:53:16 EST 2005
Ken and All,
Thanks for the help. I really appreciate it. Here is what worked for me:
LAYER
# amphib
NAME "amphib"
STATUS DEFAULT
TYPE POINT
CONNECTIONTYPE OGR
CONNECTION "admiralty_amphib.mdb,amphib_point"
END
And I'd like to thank the people that made pgeo happen as well. Definitely
good timing. I'm going to be able to do something cool thanks to ogr
geodatabase support.
On Wed, 16 Nov 2005 15:07:37 -0800, Ken Lord <kenlord at GMAIL.COM> wrote:
>Hi Edwin,
>You should be able to use the geodatabase file by using OGR as the
>connectiontype and the name of the .mdb file as the connection
>Unfortuneatly It seems I deleted my map file that I tested it with, so
>I can't give you excactly how I did it, but it did work for me. I was
>using shp2image from the latest FWTools package.
>For the connection, try the name of the .mdb followed by a comma,
>followed by the layer name ... or layer number as found by using
>ogrinfo on the geodatabase.
>... Also, a big Thanks to Frank Warmerdam who built the
>OGR/mapserver/geodatabase functionality recently, contracted by a few
>of us from the MapServer community.
