Ttf problems with php_mapscript and php as dso in apache2
JP Liska
jp at GUATEC.COM
Fri Nov 18 18:11:33 EST 2005
Hello,
I've been using mapserver 4.4 with php as cgi for a long while. I am
interested in using php as dso. I am trying out mapserver 4.8.0-beta1 and I
am able to generate an image with shp2img, however when I use this map file
with php_mapscript, the process never completes. Note that if I change the
font to bitmap, I have no problems at all.
Is it supposed to be possible to use php_mapscript in php as dso?
Has anyone else had this problem?
Thanks in advance
-Juan
I'm configuring with this:
./configure --without-tiff --without-pdf --without-eppl
--with-proj=/dls/gis/proj-4.4.9 --with-postgis --without-wms
--with-php=/dls/php/php-5.1.0RC4 --enable-debug --with-jpeg=/usr
--with-ming=/dls/ming-0.3beta1/src --with-freetype=/usr/bin/freetype-config
--with-threads
I get this when I run configure:
checking for FT_Init_FreeType in -lfreetype... yes
using libfreetype -lfreetype from system libs.
checking for gdFontGetTiny in -lgd... yes
using GD ( -DUSE_GD_GIF -DUSE_GD_PNG -DUSE_GD_JPEG -DUSE_GD_WBMP
-DUSE_GD_FT -DGD_HAS_GDIMAGEGIFPTR -DGD_HAS_GETBITMAPFONTS) from system
libs.
I'm testing with the following map file:
MAP
NAME "Testing"
EXTENT -90.539942 14.608652 -90.531052 14.617541
IMAGETYPE PNG
IMAGECOLOR 255 255 255
STATUS ON
SIZE 200 200
FONTSET "fonts.txt"
LAYER
NAME paises
TYPE polygon
STATUS on
DATA countries
LABELITEM "country"
CLASS
COLOR 248 240 220
OVERLAYSIZE 3
OVERLAYOUTLINECOLOR 100 100 100
SIZE 1
STYLE
ANTIALIAS true
END
LABEL
TYPE TRUETYPE
FONT "Vera"
SIZE 10
COLOR 0 0 0
END
END
END
END
