Hardware for serving lot's of Raster
Shawn Wallbridge
shawn at SYNACK-HOSTING.COM
Mon Nov 21 01:05:02 EST 2005
On 20-Nov-05, at 11:07 PM, Ken Lord wrote:
> Hi Shoaib, Ed,
<snip>
> IDE RAID is still limited to the
> 133Mb/s IDE bandwidth limit, the more drives you add, the more you
> will hit the bandwidth limit.
I would like to comment on this one portion, everything else was
excellent information.
The bandwidth limit of an IDE RAID controller varies GREATLY depending
on the design. Low end 'consumer' IDE 'RAID' controllers like the
cheaper Promise controllers are limited because a) they are software
based, so the CPU handles all the RAID functionality and b) they tend
to use multiple drives per IDE channel. The higher end cards like the
3Ware (my favourite) or the Adaptec controllers are vastly different,
they use one drive per channel (so their is no contention) and use
dedicated processors for the parity calculations instead of the CPU. If
you set up a RAID 0 array (not that that is _really_ raid) you would be
able to get much much more than 133Mb/s out of a _real_ raid
controller.
I have about 8TB of data on 3Ware 750x series IDE controllers and they
perform very well. I also have about 8TB of data on 3Ware 950x S-ATA
controllers and they also perform well. I am looking forward to
building a new server with the 9550SX series S-ATA II controller.
<snip>
shawn
