DBASE file error. Item 'nombredep' not found.
Alejandro Mejia Evertsz
amejia at GUA.NET
Mon Nov 21 09:51:47 EST 2005
Hi list!
I'm new to this mapserver stuff, and I'm having a trouble for creating a
map.
I have a map called guate.map with only one layer (to start getting used to
mapserver).
The layer uses deptoswgs84.shp <http://168.234.218.12/deptoswgs84.shp> ,
deptoswgs84.shx <http://168.234.218.12/deptoswgs84.shx> and deptoswgs84.dbf
<http://168.234.218.12/deptoswgs84.dbf>
Database (.dbf) has a column called "nombredep" and I created a class item
under the layer with this name, but the server returns:
I don't know what else to do, cause I even changed the name of the column to
change the class item then, but have the same problem.
Is the database file corrupted or not compatible with mapserver?
Am I doing something wrong?
Am I missing any parameters in the map file?
You can see the error here:
http://168.234.218.12/mapservdemo/
(I'm using the Itasca demo templates cause I'm not an expert with this
mapserver thing, and I don't wanna create my own html's and have more
mistakes than now)
Thanks for your help and your time.
Cheers.
Alejandro Mejia
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051121/9833462d/attachment.html
