DBASE file error. Item 'nombredep' not found.
Wim Blanken
w.blanken at GEON.NL
Mon Nov 21 10:26:05 EST 2005
Hello Alejandro,
I think this has to do with the 8 character limit with dbf files.
Have you tried limities the shapefile name to 8 characters?
Regards,
Wim Blanken
Geon bv
The Netherlands
----- Original Message -----
From: "Alejandro Mejia Evertsz" <amejia at GUA.NET>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Monday, November 21, 2005 4:14 PM
Subject: Re: [UMN_MAPSERVER-USERS] DBASE file error. Item 'nombredep' not
found.
> Thanks Lowell,
> I opened the .dbf file on Map Maker's database editor utility, and noticed
> the column name is all UPPERCASE, but I tried lowecase and lowercase with
> same results.
> NOMBREDEP and nombredep
> If case is important to mapserver, I'll save it now with uppercase.
> I also tried to remove the quotes "" but same thing.
> Thanks again for your help.
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Lowell.Filak
> Sent: Lunes, 21 de Noviembre de 2005 09:03 a.m.
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> found.
> Mejia Evertsz writes:
>> Hi list!
>> I'm new to this mapserver stuff, and I'm having a trouble for creating
>> a map.
>> I have a map called guate.map with only one layer (to start getting
>> used to mapserver).
>> The layer uses deptoswgs84.shp <http://168.234.218.12/deptoswgs84.shp>
>> , deptoswgs84.shx <http://168.234.218.12/deptoswgs84.shx> and
>> deptoswgs84.dbf <http://168.234.218.12/deptoswgs84.dbf>
>> Database (.dbf) has a column called "nombredep" and I created a class
>> item under the layer with this name, but the server returns:
>> I don't know what else to do, cause I even changed the name of the
>> column to change the class item then, but have the same problem.
>> Is the database file corrupted or not compatible with mapserver?
>> Am I doing something wrong?
>> Am I missing any parameters in the map file?
>> You can see the error here:
>> http://168.234.218.12/mapservdemo/
>> (I'm using the Itasca demo templates cause I'm not an expert with this
>> mapserver thing, and I don't wanna create my own html's and have more
>> mistakes than now)
> Alejandro,
> Double check capitalization of the item name.
> HTH
> Lowell
