DBASE file error. Item 'nombredep' not found.
Alejandro Mejia Evertsz amejia at GUA.NET
Mon Nov 21 10:14:43 EST 2005
Thanks Lowell,
I opened the .dbf file on Map Maker's database editor utility, and noticed
the column name is all UPPERCASE, but I tried lowecase and lowercase with
same results.
NOMBREDEP and nombredep
If case is important to mapserver, I'll save it now with uppercase.
I also tried to remove the quotes "" but same thing.
Thanks again for your help.
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Lowell.Filak
Sent: Lunes, 21 de Noviembre de 2005 09:03 a.m.
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] DBASE file error. Item 'nombredep' not
found.
Alejandro Mejia Evertsz writes:
> Hi list!
> I'm new to this mapserver stuff, and I'm having a trouble for creating
> a map.
> I have a map called guate.map with only one layer (to start getting
> used to mapserver).
> The layer uses deptoswgs84.shp <http://168.234.218.12/deptoswgs84.shp>
> , deptoswgs84.shx <http://168.234.218.12/deptoswgs84.shx>  and
> deptoswgs84.dbf <http://168.234.218.12/deptoswgs84.dbf>
> Database (.dbf) has a column called "nombredep" and I created a class
> item under the layer with this name, but the server returns:
> I don't know what else to do, cause I even changed the name of the
> column to change the class item then, but have the same problem.
> Is the database file corrupted or not compatible with mapserver?
> Am I doing something wrong?
> Am I missing any parameters in the map file?
> You can see the error here:
> http://168.234.218.12/mapservdemo/
> (I'm using the Itasca demo templates cause I'm not an expert with this
> mapserver thing, and I don't wanna create my own html's and have more
> mistakes than now)
Alejandro,
Double check capitalization of the item name.
HTH
Lowell
