can MapServer run on multiple cpu machines?
Xin crazygecko at GMAIL.COM
Mon Nov 21 11:06:57 EST 2005
James,
Thanks for the reply.
I see what you're saying. Having multiple instances of MapServer taking
advantage of multiple CPUs is great, just what I'm looking for. Will this be
done automatically? That is to say, will new MapServer instances
automatically use other CPUs, or does it require manual setup. Perhaps
Apache 2.0's multithreading abilities will handle this.
Thanks,
 Xin
On 21/11/05, James Lindstorff <jlindstorff at gmail.com> wrote:
> The single mapserver process will not be able to take advantage of a
> multi cpu machine.
> On the other hand if it's through put you need more instances of
> mapserver can run simultanious om multiple CPU. That is you can serve
> for instance two request at the same time, but the single mapserver
> instance will not gain anything directly by multiple CPU's.
> On 11/21/05, Xin <crazygecko at gmail.com> wrote:
> > Hi,
> > Can MapServer run on multiple cpu machines? This would save us some
> money
> > by buying dual cpu machines, rather than single ones. Since we'll be
> able
> > to have a lot more processing power for less machines. I was just on the
> > phone to people at Rackspace, and they tell me the application has to be
> > multithreaded. Is MapServer multithreaded?
> > Also, can mapserver take full advantage of dual cores? I read somewhere
> > that they are different to dual cpus. Forgive me if they are!
> > Appreciate the help.
> > Cheers,
> > Xin
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051121/4f920860/attachment.html
