can MapServer run on multiple cpu machines?
James Lindstorff
jlindstorff at GMAIL.COM
Mon Nov 21 11:21:37 EST 2005
Don't know your OS but if you run apache in prefork-mode to will
happen "automatically" in that your OS will schedule the instances to
run on an idle CPU.
On 11/21/05, Xin <crazygecko at gmail.com> wrote:
> James,
> Thanks for the reply.
> I see what you're saying. Having multiple instances of MapServer taking
> advantage of multiple CPUs is great, just what I'm looking for. Will this
> be done automatically? That is to say, will new MapServer instances
> automatically use other CPUs, or does it require manual setup. Perhaps
> Apache 2.0's multithreading abilities will handle this.
> Thanks,
> Xin
> On 21/11/05, James Lindstorff <jlindstorff at gmail.com> wrote:
> > The single mapserver process will not be able to take advantage of a
> > multi cpu machine.
> > On the other hand if it's through put you need more instances of
> > mapserver can run simultanious om multiple CPU. That is you can serve
> > for instance two request at the same time, but the single mapserver
> > instance will not gain anything directly by multiple CPU's.
> > On 11/21/05, Xin <crazygecko at gmail.com > wrote:
> > > Hi,
> > > Can MapServer run on multiple cpu machines? This would save us some
> money
> > > by buying dual cpu machines, rather than single ones. Since we'll be
> able
> > > to have a lot more processing power for less machines. I was just on
> the
> > > phone to people at Rackspace, and they tell me the application has to be
> > > multithreaded. Is MapServer multithreaded?
> > > Also, can mapserver take full advantage of dual cores? I read
> somewhere
> > > that they are different to dual cpus. Forgive me if they are!
> > > Appreciate the help.
> > > Cheers,
> > > Xin
