Dynamic points and labels
dldeskins at GMAIL.COM dldeskins at GMAIL.COM
Mon Nov 21 16:08:14 EST 2005
I have written a function that is used place points dynamically on a map
from session variables:
 function addPoints(&$map,&$image,$xCoor,$yCoor, $symbol, $text)
  $my_layer = ms_newLayerObj($map);
  $my_layer->set("name", "myLayer");
  $my_layer->set("type", MS_LAYER_POINT);
  $my_layer->set("status", MS_ON);
  $my_layer->set(transparency, 75);
  $pt = ms_newPointObj();
  $ln = ms_newLineObj();
  $shp = ms_newShapeObj(MS_SHAPE_POINT);
  // these are pixel coordinates because TRANSFORM is FALSE
  $pt->setXY($xCoor, $yCoor);
  $ln->add($pt);
  $shp->add($ln);
  $my_class = ms_newClassObj($my_layer);
  $my_class->label->set("font", "arial-bold");
  $my_class->label->set("type", MS_TRUETYPE);
  $my_class->label->set("size", 7);
  $my_class->label->color->setRGB(255, 0 , 0);
  $my_class->label->backgroundcolor->setRGB(255, 255 , 255);
  $my_class->label->set("position", MS_LC);
  $my_class->label->set("force", MS_TRUE);
  $my_class->label->set("partials", MS_TRUE);
  $my_class->label->set("buffer", 0);
  $shp->set("text", stripslashes($text));
  $my_style = ms_newStyleObj($my_class);
  if($symbol == "g")
   $my_style->set("symbolname","star_green");
  elseif($symbol == "b")
   $my_style->set("symbolname","star_blue");
  $my_layer->addFeature($shp);
  $my_layer->draw($image);
The symbols are showing in the proper place. The problem that I am having is
that the label will not show. Can anyone see a problem with the function?  I
would eventually like to set the font, color, size dynamically also.
Thanks
