PDF Output in Mapserver
Luca Casagrande
luca.casagrande at GMAIL.COM
Tue Nov 22 06:24:55 EST 2005
On Monday 21 November 2005 21:22, Sears, Jeremy wrote:
> Good Day All,
> I'm attempting to create a button that allows clients to have a pdf image
> of a map streamed to their browser.
> Im using the following document as a guide:
> http://mapserver.gis.umn.edu/cgi-bin/wiki.pl?PHPMapscriptPDF
> Im running MS4W with Chameleon on an XPbox.
> I have a newbie question for anyone with any knowledge in this area. Where
> do I add/modify code as described in this doc? Do I create a widget to
> implement the pdf output? Do I modify the existing PrintProduction widget?
> or should I be thinking about coding elsewhere in my files?
> I've go PDFlib(demo) working with my php install and can successfully
> execute the PDF generating php code.
> Any suggestions would be greatly appreciated.
> Best Regards
> Jeremy
You can ceck this: http://pmapper.sourceforge.net
it has got html and pdf printing
Bye
Luca
