WMS GetFeatureInfo problem with ArcSDE layer
Ian Miller
ian.miller at SPATIALVISION.COM.AU
Tue Nov 22 06:30:07 EST 2005
Bart,
Thanks for your quick response!
The table had only the normal ArcSDE applied OBJECTID unique index
and no separate user primary key, although other layers that work
correctly have the same setup.
I've tried adding a separate user PK on another column but it doesn't
help the problem.
One further interesting (and confusing) fact is that out of the 200
or so features in this layer, a small number return the correct value
when clicked. Seems to be no pattern (spatial or attribute-wise) as
to which features work correctly - maybe its just co-incidence, I
guess even randomly some will be correct!?
At 10:09 PM 22/11/2005, you wrote:
>With respect to your first problem (results are totally off), does
>your table have a primary key?
>Best regards,
>Bart
>Bart van den Eijnden
>Syncera IT Solutions
>Postbus 270
>2600 AG DELFT
>tel.nr.: 015-7512436
>email: BEN at Syncera-ITSolutions.nl
> >>> Ian Miller <ian.miller at SPATIALVISION.COM.AU> 11/22/2005 11:55:55 AM >>>
>I have a mapserver map file with many ArcSDE layers defined in it and am
>calling this via a WMS client. For many layers (point and polygon), the
>GetFeatureInfo request works correctly, returning a GML string with the one
>or many results.
>For a number of layers however, both point and polygon, I am getting one of
>two different errors. In some cases, the feature(s) returned are nowhere
>near the point clicked, even though the BBOX coordinates included in the
>request are correct. eg for the request:
>http://203.21.120.26/cgi-bin/mapserv?
>map=amsis.map&VERSION=1.0.0&SERVICE=WFS&REQUEST=GetFeature&MAXFEATURES=100&O
>UTPUTFORMAT=GML2&TYPENAME=PETROLEUMWELLS&BBOX=119.7781007751938,-
>17.236434108527135,119.88791989664084,-17.126614987080103
>the return is:
><?xml version='1.0' encoding="ISO-8859-1" ?><wfs:FeatureCollection
>xmlns:myns="http://www.ttt.org/myns"
>xmlns:wfs="http://www.opengis.net/wfs"
>xmlns:gml="http://www.opengis.net/gml"
>xmlns:ogc="http://www.opengis.net/ogc"
>xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>xsi:schemaLocation="<http://www.opengis.net/wfs>http://www.opengis.net/wfs
>http://schemas.opengeospatial.net/wfs/1.0.0/WFS-
>basic.xsd http://www.ttt.org/myns
>map=amsis.map&SERVICE=WFS&VERSION=1.0.0&REQUEST=DescribeFeatureT
>ype&TYPENAME=PETROLEUMWELLS&OUTPUTFORMAT=XMLSCHEMA">
><gml:boundedBy> <gml:Box srsName="EPSG:4326">
> <gml:coordinates>119.822556,-17.166944 119.822556,-
>17.166944</gml:coordinates> </gml:Box> </gml:boundedBy>
><gml:featureMember> <myns:PETROLEUMWELLS>
> <gml:coordinates>144.671667,-8.282500 144.671667,-
>8.282500</gml:coordinates> </gml:Box>
></gml:boundedBy> <myns:msGeometry> <gml:Point
>srsName="EPSG:4326"> <gml:coordinates>144.671667,-
>8.282500</gml:coordinates> </gml:Point>
></myns:msGeometry> <myns:OBJECTID>595</myns:OBJECTID>
><myns:FEATURETYPE>Petroleum Well</myns:FEATURETYPE>
><myns:ENO>10567</myns:ENO> <myns:WELL>Dibiri 1A</myns:WELL>
><myns:TOTALDEPTH>4895</myns:TOTALDEPTH>
><myns:STATUS>Dry</myns:STATUS> <myns:OPERATOR>Phillips Aust Oil
>Co</myns:OPERATOR> <myns:CONTRACTOR></myns:CONTRACTOR>
><myns:TITLE></myns:TITLE> <myns:SHORE></myns:SHORE>
><myns:FIELD></myns:FIELD> <myns:WELLTYPE></myns:WELLTYPE>
><myns:ELEVATION>&lt;null&gt;</myns:ELEVATION>
><myns:SOURCE>Geoscience Australia</myns:SOURCE>
><myns:SCALE>10000000</myns:SCALE>
><myns:ACCURACYESTIMATE>0</myns:ACCURACYESTIMATE>
><myns:DATACURRENCY>00:00:00 05/25/2005</myns:DATACURRENCY>
><myns:UPDATEFREQUENCY>5</myns:UPDATEFREQUENCY>
><myns:CREATIONDATE>&lt;null&gt;</myns:CREATIONDATE>
><myns:RETIREMENTDATE>&lt;null&gt;</myns:RETIREMENTDATE>
><myns:PID>&lt;null&gt;</myns:PID>
><myns:SYMBOL>0</myns:SYMBOL>
><myns:SHAPE>&lt;shape&gt;</myns:SHAPE>
><myns:SE_ROW_ID>561</myns:SE_ROW_ID> </myns:PETROLEUMWELLS>
></gml:featureMember></wfs:FeatureCollection>
>You can see the gml:boundedBy box coordinates match the request BBOX
>coordinates but the returned feature is in a totally different place. If I
>query this ArcSDE layer from a client like ArcMap it works correctly. Note
>that if I export the ArcSDE layer to a shapefile and use that with
>mapserver, the result is also correct.
>Possibly related, some polygon layers also fail, although the symptoms are
>different. In that case I get a truncated return GML string such as:
><?xml version="1.0" encoding="ISO-8859-1"?><msGMLOutput
>xmlns:xlink="http://www.w3.org/1999/xlink"
>xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
> <PETROLEUMACREAGERELEASE_layer>
>which would appear to indicate that the process terminated abnormally mid
>request but if I use a debug-enabled version of mapserver I don't see any
>error message. Again, exported to shapefiles the request works correctly.
>Note that in both cases if I use a WFS GETFEATURE in place of the WMS
>GetFeatureInfo I get similar errors.
>Can anyone help?
Regards
Ian Miller
SPATIAL VISION
Phone: +61 3 9691 3034
Fax: +61 3 9691 3001
Mobile: 0419 185 470
E-mail: Ian.Miller at spatialvision.com.au
For the latest news visit http://www.spatialvision.com.au/
This e-mail is privileged and confidential and intended only for
the addressee(s). If received in error please delete and advise
Spatial Vision by return e-mail.
