Thematic mapping
Bart van den Eijnden
BEN at SYNCERA-ITSOLUTIONS.NL
Thu Nov 24 00:59:03 EST 2005
Search in the archive for pie chart. There was a nice example by Steve Lime end of 2004. See below.
Best regards,
Bart
Forwarded message:
Hi all: I was updating mapgd.c today to make use of GD functions that
appeared in GD 2.0.x. I made a small modification to the marker drawing
code for ELLIPSE symbols, specifically circles. Now if you specify a
style angle it is interpreted as a "pie slice". You can do things like:
http://maps.dnr.state.mn.us/testing/charts/test.gif
http://maps.dnr.state.mn.us/testing/charts/test.map
Since you can load an angle from an attribute (via ANGLEITEM) you can
build simple pie charts pretty easy. Only problem is it's hard to do
more than 2 colors, and the origin is always 0.
Assuming folks are ok with the modification (it's only 5 lines of code)
what about adding a STARTANGLE parameter? We could probably do some auto
computation of starting angles between styles so that multiple element
charts would be possible/easy to construct.
Steve
Syncera IT Solutions
Postbus 270
2600 AG DELFT
tel.nr.: 015-7512436
email: BEN at Syncera-ITSolutions.nl
>>> Paul james <pauljame at GMAIL.COM> 11/23/2005 7:43 PM >>>
Hi all... Is it posible to make Thematic mapping with mapserver? I need
associante some graph with my map ( Each state with a pizza diagram )..
How can I do that?
ty
