Cleaning Shapefiles and creating a coverage
Dylan Beaudette
dylan.beaudette at GMAIL.COM
Mon Nov 28 00:10:44 EST 2005
On Nov 27, 2005, at 8:30 PM, David Hunt wrote:
> I want to insure that the external boundary of polygon has its
> vertices oriented
> clockwise and the vertices of interior voids are oriented
> counter-clockwise.
> Also the goal is to remove the duplicate edges that are shared among
> polygons
> because I need the shapefile to be converted into a coverage.
> Basically I want the clean tool to perform the functionality of ESRI's
> CleanShapeFile.exe.
> Thanks
> Dave
> Quoting Stephen Woodbridge <woodbri at SWOODBRIDGE.COM>:
>> Hi Dave,
>> What type of cleaning do you want to do?
>> What do you expect such a utility to do?
>> -Steve
>> David Hunt wrote:
>>> Hello all,
>>> Does anyone know of a free utility to clean shapefiles? I am also
>>> looking
>> for a
>>> utility to take a coverage and convert it into a coverage.
>>> Thanks for the help.
>>> David
>>> hunt at eecs.orst.edu
Dave,
I think what you are referring to is "topological cleaning" of a
shapefile: i.e. convert a shapefile to an ESRI coverage via building of
topology.
GRASS can build a topologically correct vector from a shapefile, which
can then be exported to a variety of formats which can be converted
into a "Coverage" .
Cheers,
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
