mapserver - windows 2003
Bart van den Eijnden
bartvde at XS4ALL.NL
Mon Nov 28 09:46:11 EST 2005
are you sure all the dll's can be found by Mapserver? Can you do mapserv
-v in a DOS command prompt, or use a dependency checker tool to analyze
this (like depends)?
You also need to create a Web Service Extension for the mapserv CGI
process in the IIS Manager.
A Windows 2000 version guide is available here:
http://ms.gis.umn.edu/docs/howto/setupiis
Best regards,
Bart
> hi,
> I have developed a couple of maps wtih apache and postgis, but now I
> need to migrate it to windows 2003, using de windows web server. So, for
> php and postgis there was no problem, but mapserver doesn't work. I do
> what the README-Install.txt says, (using C:/Inetpub/wwwroot/cgi-bin for
> mapserv.exe), but when enter the link
> "http://localhost/cgi-bin/mapserv.exe", but I recieve a "HTTP 500
> internal server error" The page cannot be displayed, blablabla.
> Does somebody knows, how to successfully install mapserver under windows
> using IIS, or where is my problem??
> thanks,
> Mauricio Stange H.
