mapserver - windows 2003
Mauricio Stange H. mstangeh.foros at GMAIL.COM
Tue Nov 29 06:39:43 EST 2005
Thanks,
    now it works, at least it throws me that there is no querystring
when I go to the http://localhost/mapserv... direction.
    but I'm having a problem with the php, I says *
"Security Alert!* The PHP CGI cannot be accessed directly.
This PHP CGI binary was compiled with force-cgi-redirect enabled. This
means that a page will only be served up if the REDIRECT_STATUS CGI
variable is set, e.g. via an Apache Action directive."
how do I resolve this..
Mauricio Stange H.
Bart van den Eijnden wrote:
>Hi,
>are you sure all the dll's can be found by Mapserver? Can you do mapserv
>-v in a DOS command prompt, or use a dependency checker tool to analyze
>this (like depends)?
>You also need to create a Web Service Extension for the mapserv CGI
>process in the IIS Manager.
>A Windows 2000 version guide is available here:
>http://ms.gis.umn.edu/docs/howto/setupiis
>Best regards,
>Bart
>>hi,
>>    I have developed a couple of maps wtih apache and postgis, but now I
>>need to migrate it to windows 2003, using de windows web server. So, for
>>php and postgis there was no problem, but mapserver doesn't work. I do
>>what the README-Install.txt says, (using C:/Inetpub/wwwroot/cgi-bin for
>>mapserv.exe), but when enter the link
>>"http://localhost/cgi-bin/mapserv.exe", but I recieve a "HTTP 500
>>internal server error" The page cannot be displayed, blablabla.
>>Does somebody knows, how to successfully install mapserver under windows
>>using IIS, or where is my problem??
>>thanks,
>>    Mauricio Stange H.
