PIXMAX SYMBOLS PROBLEM!!!
Fawcett, David
David.Fawcett at STATE.MN.US
Tue Nov 29 09:55:58 EST 2005
Stefano,
Did you try the suggestions that I sent to you and the list on
11/26/2005?
Here was my response:
Try removing the minscale and maxscale from the point layer and see if
they continue to work.
I also see that the layer status is set to on. Do you have a control on
your template that tells mapserver to display that layer? With status of
on, you need to specify the layer name in the URL or post that calls the
mapserver. Try setting the layer status to default and see if that fixes
the issue.
David.
David.
-----Original Message-----
[mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Dott. Stefano
Albanese
Sent: Tuesday, November 29, 2005 8:35 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] PIXMAX SYMBOLS PROBLEM!!!
Here is my mapfile:
# Start of map file - created Sat Nov 26 05:30:10 2005
NAME 'Sirignano'
STATUS ON
PROJECTION
'init=epsg:4326'
END
SIZE 550 646
EXTENT 2488215.224 4532635.713 2489404.490 4534031.661
UNITS meters
FONTSET 'D:/ms4w/Apache/htdocs/sirignano/fonts/fonts.fnt'
IMAGECOLOR 255 255 255
# Start of web interface definition
WEB
LOG Sirignano.log
TEMPLATE sirignano.html
IMAGEPATH 'D:/ms4w/Apache/htdocs/temp/'
IMAGEURL 'http://localhost/temp/'
EMPTY 'http://localhost/sirignano/nothing.html'
# change this value to match your setup
METADATA
WMS_ONLINERESOURCE
'http://localhost//cgi-bin/mapserv.exe?map=D:/ms4w/Apache/htdocs/sirigna
no/Sirignano.map'
'WMS_SRS' 'epsg:4326'
WMS_ACCESSCONSTRAINTS 'none'
WMS_TITLE 'Sirignano'
WMS_FEATURE_INFO_MIME_TYPE 'text/html'
WMS_ABSTRACT ''
END #METADATA
END #HEADER
# Properties for the querymap
QUERYMAP
SIZE 200 200
STATUS ON #OFF
STYLE HILITE
COLOR 255 0 0
END
# Start of reference map
REFERENCE
STATUS ON
IMAGE graphics/map_ref.png
SIZE 120 80
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
END #REFERENCE
# Start of symbol
SYMBOL
NAME 'albero'
TYPE PIXMAP
IMAGE 'd:/ms4w/apache/htdocs/sirignano/symbols/albero.gif
END #Symbol
LAYER
NAME 'Alberi.shp'
DATA 'd:/ms4w/apache/htdocs/sirignano/data/alberi'
STATUS ON
TYPE Point
MINSCALE 200
MAXSCALE 200000
SYMBOLSCALE 3000
CLASSITEM 'Entity'
CLASS
NAME ' '
_EXPRESSION 'Point'
COLOR 0 0 0
SYMBOL 'albero'
END
END # END OF LAYERFILE
END # MAPFILE
Thanx a lot!
Dott. Geol. Stefano Albanese
Via S. Giacomo 6
83022 Baiano (AV)
Italia
Tel.: +390818243143
+393471982279
Yahoo! Music Unlimited - Access over 1 million songs. Try it
free.
<http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=36035/*http://music.yah
oo.com/unlimited/>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051129/5b1da164/attachment.html
