creating shape for querying
Ethan Alpert
ealpert at DIGITALGLOBE.COM
Tue Nov 29 11:46:03 EST 2005
Although I don't use PHP...I regularly create shapes and call
queryByShape() using them as the query shape in perl.
I do know that the layer *being* queried can not be an inline layer and
must be a true data source.
-e
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Fx Gamoy
Sent: Tuesday, November 29, 2005 9:29 AM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] creating shape for querying
hello Ethan
i get "[Tue Nov 29 15:27:49 2005] [error] [client 127.0.0.1] Premature
end of script headers: php.exe"
but when i use the shape $oGeo and add it into a dynamic layer, it is
well computed so i think it is in a good form enven if the bounds of the
shape are disabled (-1)
did you already query a layer by shape using such manually created
shape?
thanks
best regards
fx
Selon Ethan Alpert <ealpert at DIGITALGLOBE.COM>:
> Are you getting an error message or is it just not returning you
> expected restuls?
> e
> On Behalf Of Fx Gamoy
> Sent: Tuesday, November 29, 2005 9:06 AM
> Yes, sorry,
> you must read querybyshape of course :-)
> $rep=@$oLayer->queryByShape($oGeo);
> but php fails anyway with querybyshape
> thanks
> fx
> Selon Ethan Alpert <ealpert at digitalglobe.com>:
> > queryByRect takes a rectObj not a shapeObj. You need to either use
> > queryByShape or create a rectObj.
> > -e
> > Sent: Tuesday, November 29, 2005 7:52 AM
> > Subject: [UMN_MAPSERVER-USERS] creating shape for querying
> > Hello everybody,
> > i would like to create a shape in order to querybyshape a layer. I
> > ve got two arrays xgeo and ygeo
> > $oGeo = ms_newShapeObj(MS_SHAPE_POLYGON);
> > $part = ms_newLineObj();
> > for($v=0;$v<count($xgeo);$v++)
> > $part->addXY($xgeo[$i],$ygeo[$i]);
> > $oGeo->add($part);
> > $rep=@$oLayer->queryByRect($oGeo);
> > the bounds of this shape are (-1,-1,-1,-1) but i can add it in a
> > dynamic layer and see it on the computed image. but when i use this
> > shape into querybyshape, php fail
> > I ve read some posts dealing with this? the php_mapscript 4.6 don't
> > provide the
> > $Shape->setbounds() function for setting the bounds of the shape.
> > is there un artefact to compute a querybyshape using a self created
> > shape??
> > Thanks.....
> > have a nice day
> > fx
> > This message was sent using IMP, the Internet Messaging Program.
