MapTools & Foundation
Paul Spencer pspencer at DMSOLUTIONS.CA
Wed Nov 30 17:21:23 EST 2005
Good question.  MapTools will continue to exist as is for now.
There was some discussion of the MapTools name being donated to the
new Foundation for exactly the reasons you have indicated, but
ultimately the folks around the table wanted a name that was not
already associated with a commercial entity.  While we have tried to
make MapTools pretty neutral, it is associated with DM Solutions Group.
What happens to projects that are hosted on MapTools right now is
probably up to the individual projects.  It has not yet been
established what the rules of membership in the new foundation will
be so not all projects may even be eligible for membership (although
I hope that is not the case).
Cheers
Paul
On 30-Nov-05, at 4:57 PM, M Joonas Pihlaja wrote:
> Hi all,
> Where does maptools.org fit into all this?  Is the plan that
> libraries like GDAL/Shapelib/etc be then moved over to be the
> foundation's projects?
> Or going the other way, was a Map Tools Foundation considered?
> Seems like it would be a good umbrella for lots of diverse
> projects including the two map servers.  The domain's right
> there, and I'd hate to see function of maptools.org as a focal
> point of open source GIS be split off into two.  (Although, I'm
> not sure if the projects on maptools would all care to be
> subsumed into a foundation.)
> Cheers,
> Joonas
|Paul Spencer                           pspencer at dmsolutions.ca   |
|Applications & Software Development                              |
|DM Solutions Group Inc                 http://www.dmsolutions.ca/|
