Fwd: [gislist] Mxp -> map conversion
Jeroen Ticheler
Jeroen.Ticheler at FAO.ORG
Wed Oct 5 04:25:12 EDT 2005
> Hi,
Posting this message (from the gislist) to the MapServer and GeoTools
mailing lists as I think there may be interest within these
communities for this tool. An earlier post a couple of months ago
didn't generate a single reply, so I may be wrong :-)
> I've developed a tool to export an MXD to an AXL (ArcIMS)
> configuration file. It works on both ArcMap 8 and 9 and does
> conversions of all (risky statement...) the symbology of ArcMap (both
> for vector and raster & truetype symbols on most supported data
> formats).
> I have tried to get someone interested in developing an XSL
> transformation of these AXL files into MapServer map files (or
> SLD), but no
> one reacted unfortunately and I do not have the MapServer knowledge
> required nor the time to develop these. However, if someone creates
> such XSL (even starting with something fairly basic) I would be very
> happy to incorporate the functionality as one of the export formats
> of the tool.
> You can find the tool in the ArcScripts section on the
> support.esri.com website . The tool's name is MXD2AXL
> Greetings,
> Jeroen
> On 26 Sep 2005, at 16:46, Ed Dowding wrote:
>> Thanks, Jeff, for the useful reply.
>> Would anyone be able to help with the conversion? I have just one
>> file
>> (about 450k) that needs converting from mxd to .map.
>> I have no idea if this is a lengthy process or not, but if it is
>> obviously
>> there will be remuneration.
>> Please contact me off list if you're interested.
>> TIA,
>> Ed.
>> Ed Dowding ed at usology.com
>> Usology Ltd http://www.usology.com
>> [mob] +44 (0)7775 79 18 14 [sky] ed_usology
>> [tel] +44 (0)20 7871 18 14 (c)2005 Usology Ltd
>> -----Original Message-----
>> From: gislist-bounces at lists.geocomm.com
>> [mailto:gislist-bounces at lists.geocomm.com] On Behalf Of Jeff McKenna
>> Sent: 26 September 2005 13:50
>> To: gislist at lists.thinkburst.com
>> Subject: Re: [gislist] Mxp -> map conversion
>> Amein! is the mxd-to-map utility, Avein! is the apr-to-map
>> utility...if
>> you use ArcGIS 9 you should be able to use Amein! (same URL as you
>> stated).
>> Another good apr-to-mxd utility is Gix (http://gix.sourceforge.net/),
>> but the mxd-to-map utility is in development (according to the
>> website).
>> Quantum GIS (QGIS, http://www.qgis.org/) does have an 'Export as
>> MapServer mapfile) option, but the last time i tried it it was
>> still not
>> fully functional.
>> jeff
>> Ed Dowding wrote:
>>> Hi ~
>>> I'm using MapServer (http://mapserver.gis.umn.edu/) on a project,
>>> and need
>>> to show style data with the information from an .mxp file.
>>> Alas mapserver doesn't support this format.
>>> Can anyone help?
>>> Would it be possible either to:
>>> o Convert the mxd to a map file using ArcView and Avein!
>>> (http://sourceforge.net/projects/avein/)
>>> o Give us some kind of human-readable version of the mxd file so
>>> we can
>>> code the map file ourselves
>>> Thanks, gislist,
>>> Ed.
>> Jeff McKenna
>> DM Solutions Group Inc.
>> http://www.dmsolutions.ca
>> gislist mailing list
>> gislist at lists.geocomm.com
>> http://lists.geocomm.com/mailman/listinfo/gislist
>> This list is brought to you by
>> The GeoCommunity
>> http://www.geocomm.com/
>> The GeoCommunity
> The GeoCommunity
