PROJ Problem
Bart van den Eijnden bartvde at XS4ALL.NL
Tue Oct 11 14:42:29 EDT 2005
For IIS it *should* work with a system environment variable called
PROJ_LIB.
Best regards,
Bart
On Tue, 11 Oct 2005 17:55:12 +0200, Avramov,Daniel [Ontario]
<Daniel.Avramov at EC.GC.CA> wrote:
> How do we set up an Environment Variable in IIS 6 for the PROJ_LIB?
> The reason we are asking is that we are encountering problems with the
> projection library not being found.
> It is fixed when the the PROJ folder is sitting on the C: drive (Not a
> desired solution)
> OR
> It works when we have the CONFIG PROJ_LIB set in the MapFile (We do not
> want to have to do this all this time).
> We are using CWC2 which writes out a default.map file without our
> specific CONFIG PROJ_LIB statement/path.
> How would we write to the map file our CONFIG statement using php/php
> mapscript?
> Thanks in advance.
> Daniel and Debbie.
Using Opera's revolutionary e-mail client: http://www.opera.com/mail/
