Linking problems
Philip Mark Donaghy philip.donaghy at GMAIL.COM
Sat Oct 15 18:26:07 EDT 2005
Thanks Prashanth, that did it!
ln -s /usr/local/lib/libgd.so /usr/lib/libgd.so.2
Philip
On 10/15/05, Prashanth Ram <pram123 at gmail.com> wrote:
> Philip:
> Create a link to that file (from /usr/lib or /usr/local/), and everything
> should work. In order to find the file you can either do whereis
> libgd.so.2 or locate libgd.so.2.
> -Prashanth
> HTMLX.com
> Mapserver Hosting, Mapscript Hosting, PHP Hosting
> PostgreSQL w/PostGIS extension enabled Hosting
> On 10/15/05, Philip Mark Donaghy <philip.donaghy at gmail.com> wrote:
> > Thanks Pram,
> > My last problem was resolved by rerunning ./configure
> > Now that mapserv is built I tried it out and the gd library is not
> > getting linked.
> > opensource at lns-bzn-31-82-252-227-123:~/soft/bin/mapserver-4.6.1> ldd
> > mapserv
> > linux-gate.so.1 => (0xffffe000)
> > libgd.so.2 => not found
> > libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x4002b000)
> > libpng.so.3 => /usr/lib/libpng.so.3 (0x40093000)
> > libc.so.6 => /lib/tls/libc.so.6 (0x400c1000)
> > libm.so.6 => /lib/tls/libm.so.6 (0x401d7000)
> > libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x401fa000)
> > libz.so.1 => /lib/libz.so.1 (0x402b7000)
> > /lib/ld-linux.so.2 => /lib/ld-linux.so.2 (0x40000000)
> > libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x402c9000)
> > The LD_LIBRARY_PATH environment variable solves this...
> > opensource at lns-bzn-31-82-252-227-123:~/soft/bin/mapserver-4.6.1> export
> > LD_LIBRARY_PATH=/usr/local/lib
> > mapserv
> > libgd.so.2 => /usr/local/lib/libgd.so.2 (0x40018000)
> > libfreetype.so.6 => /usr/local/lib/libfreetype.so.6 (0x40065000)
> > libpng.so.3 => /usr/local/lib/libpng.so.3 (0x400cd000)
> > libc.so.6 => /lib/tls/libc.so.6 (0x40110000)
> > libm.so.6 => /lib/tls/libm.so.6 (0x40226000)
> > libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x40249000)
> > libpng12.so.0 => /usr/local/lib/libpng12.so.0 (0x40306000)
> > libgcc_s.so.1 => /lib/libgcc_s.so.1 (0x40338000)
> > Apache is having the same problem but the environment variable does not
> > resolve this. error_log...
> > [Sat Oct 15 23:59:22 2005] [error] [client ::1]
> > /home/opensource/soft/bin/httpd-2.0.54/cgi-bin/mapserv: error while
> > loading shared libraries: libgd.so.2: cannot open shared object file: No
> > such file or directory
> > Thanks for any hints,
> > Philip
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20051015/e76d040d/attachment.html
