mapserv binary file changes?
Vincent J. Troisi
vincent.troisi at COLORADO.EDU
Thu Sep 1 16:33:06 EDT 2005
No. I ran md5sum against the file before and after I
moved the file to the cgi-bin directory. At that time
the file was exactly the same. But after a day or two
the file changes (per md5sum or unix checksum).
I was just wondering if there might be some buffer overflow occuring in
the binary when in use that may be causing this problem. I'm running
on Suse Linux Enterprise 8, Apache 2 server, and Mapserver 4.6.0.
Fawcett, David wrote:
> Could you have corrupted it when you downloaded it? FTP set to ASCII?
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]On
> Behalf Of Vincent J. Troisi
> Sent: Thursday, September 01, 2005 1:07 PM
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: [UMN_MAPSERVER-USERS] mapserv binary file changes?
> Has anyone experienced this problem?
> Periodically, the mapserv binary (executable) changes. The file
> size is the same, and the time stamp is the same as when the
> file was placed in the directory, and the stats on the file
> show no modification to the file, but...the md5sum is different
> than the original file and the binary, mapserv, is unuseable.
> Thoughts...
