Non-existant Legend Functionality?
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Sep 1 17:20:23 EDT 2005
Abe,
I think this would be a very valuable extension and it would not be that
hard to implement. All that you would need is a bit array that is zeroed
before a draw request where each bit represents a unique layer-class,
then as objects are drawn you would OR 1 into the bit array for the
layer-class index if/when an object is drawn. Then you would need to be
able to query the bit array for a given layer-class index to see if it
was drawn.
-Steve W.
Abe Gillespie wrote:
> I build my legends by hand with PHP code because the native
> functionality just isn't good enough for what I need. Unfortunately I
> still can't get it perfect because of what I think is missing MapServer
> functionality. Currently my legends are just too big for printing. Is
> there a way to tell whether a certain class is visible w/i the current
> view? Now I don't mean whether the class is within it's scale limits
> (MIN or MAXSCALE). Rather can one tell if a layer / class has any data
> w/i the current view. For instance, I may have a fire hydrant layer w/o
> any scale dependencies. But I might be zoomed into a field way out in
> the country side. So, yeah, technically the layer can be seen at that
> scale, but no fire hydrants are actually in the view.
> If this doesn't exist, shall I issue a feature request?
> Thanks.
> -Abe
