Mapserver 4.6.1 Make problems - mapogr.o
Steve Benzo
steve_benzo at YAHOO.COM
Tue Sep 6 01:24:43 EDT 2005
Christian,
Danke, for that, enabling LD_OPTIONS with the /usr/lib
and /usr/local/lib solved a lot of the issues, I'm
able to make (as opposed to gmake) mapserver with a
few options now.
There's one final issue I'm confronting. When I enable
--with-wmsclient, I get this error:
ld: fatal: relocations remain against allocatable but
non-writable sections
collect2: ld returned 1 exit status
make[1]: *** [php_mapscript.so] error 1
above that are a bunch of calls for libcrypto.a,
libssl.a, and some others i think...
Any suggestions? This is on Solaris 9.
--- Christian Schaffer
<christian.schaffer at muenchen.de> wrote:
> Hello Steve,
> hi list,
> I experienced a pretty similar issue trying to
> compile 4.6.0 on Solaris
> 10 a few weeks ago. Joshua Buysse gave me the
> relevant hint to avoid the
> problem: Try to set LD_OPTIONS in your environment,
> e.g.
> LD_OPTIONS='-R/opt/csw/lib -L/opt/csw/lib
> -R/opt/csw/postgresql/lib
> -L/opt/csw/postgresql/lib -R/usr/local/lib
> -L/usr/local/lib
> -R/opt/oracle/lib -L/opt/oracle/lib'
> export LD_OPTIONS
> In your case, find the libclntsh.so.9.0 and make the
> LD_OPTIONS point to it.
> For me, that works perfectly. After recompiling with
> this option set,
> calling mapserver via web gives you the desired
> output.
> Hope that helps.
> Regards,
> Chris
> Steve Benzo schrieb:
> >Daniel,
> >>That's possible if you link with libs that are not
> >>in your default lib
> >>path settings.
> >I set the ldlibpath to the libs that mapserver
> >requires before i compile, but it doesn't seem to
> >'remember' those when it comes time to run
> mapserver
> >later? Is there a way to hard code those values at
> >compile time?
> >>Did you look in your Apache error_log to look for
> >>hints? It may be that
> >>your Apache config is also missing the
> >>ld_library_path settings, that
> >>would explain the problem, and you would see
> >>something to that effect in
> >>the error_log.
> >>Daniel
> >The error log shows the same errors I get when I
> try
> >to run mapserver without those libs defined:
> >[Fri Sep 02 16:53:03 2005] [error] [client xxx]
> >Premature end of script headers: mapserv_new
> >ld.so.1: /usr/local/apache/cgi-bin/mapserv_new:
> fatal:
> >libclntsh.so.9.0: open failed: No such file or
> >directory
> >PS Thanks a lot for your help on this!
>____________________________________________________
> >Start your day with Yahoo! - make it your home page
> >http://www.yahoo.com/r/hs
______________________________________________________________
> Landeshauptstadt München
> Referat für Gesundheit und
> Umwelt
> Informationsverarbeitung
> Christian Schaffer
> Bayerstraße 28a
> 80335 München
> Tel: 089 - 233 - 4 76 67
> Fax: 089 - 233 - 4 76 62
> http://www.muenchen.de
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
